Discuss
Water leak in back of refrigerator
 in
Refrigerator & Freezer Repair
I am trying to find the part where the water line attaches to the ice maker on the back of
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Water leak in back of refrigerator
  #1 (permalink)
Old 05-13-2010, 06:14 PM
Junior Member
JE_inc is on a distinguished road
Default Water leak in back of refrigerator
Model Number: srd20s4w   Brand: Amana   Age: 5 - 10 years
I am trying to find the part where the water line attaches to the ice maker on the back of the freezer. It is leaking where the 1/4" tubing attaches when the ice maker calls for water. It appears to be a rubber right angle connector that has a clamp holding the 1/4" line to it but I can't find a part for it on any sites that has parts for this model.
It doesn't appear to be broken, I cut a 1/2" off the tube and reinserted it thinking that that may be the problem, I also replaced the insert in the tube. Same problem. I am thinking of a small hose clamp but wanted to see if anyone out there has ever had a similar problem.
JE
Related Models
Amana SRD20S4W REF - SXS/I&W
Amana SRD20TPE REF - SXS/I&W
Amana SRD20TPW REF - SXS/I&W
Amana SRD21VE REF - SXS/I&W
Amana SRD21VL REF - SXS/I&W
Amana SRD21VW REF - SXS/I&W
Amana SRD22S3E REF - SXS/I&W
Amana SRD22S3L REF - SXS/I&W
Amana SRD22S3W REF - SXS/I&W
Amana SRD22S5E REF - SXS/I&W
Amana SRD22S5L REF - SXS/I&W
Amana SRD22S5W REF - SXS/I&W
Amana SRD22TPE REF - SXS/I&W
Amana SRD22TPSE REF - SXS/I&W
Amana SRD22TPW REF - SXS/I&W
Amana SRD22VPE REF - SXS/I&W
Amana SRD22VPL REF - SXS/I&W
Amana SRD22VPSE REF - SXS/I&W
Amana SRD22VPW REF - SXS/I&W
Amana SRD23V Ref - SXS/I&W
Amana SRD23VE REF - SXS/I&W
Amana SRD23VL REF - SXS/I&W
Amana SRD23VP Ref - SXS/I&W
Amana SRD23VPE REF - SXS/I&W
Amana SRD23VPSE REF - SXS/I&W
Amana SRD23VW REF - SXS/I&W
Amana SRD25S3E REF - SXS/I&W
Amana SRD25S3L REF - SXS/I&W
Amana SRD25S3W REF - SXS/I&W
Amana SRD25S5E REF - SXS/I&W
Amana SRD25S5L REF - SXS/I&W
Amana SRD25S5W REF - SXS/I&W
Amana SRD25TPE REF - SXS/I&W
Amana SRD25TPL REF - SXS/I&W
Amana SRD25TPSE REF - SXS/I&W
Amana SRD25TPW REF - SXS/I&W
Amana SRD25VPE REF - SXS/I&W
Amana SRD25VPL REF - SXS/I&W
Amana SRD25VPSE REF - SXS/I&W
Amana SRD25VPW REF - SXS/I&W
Amana SRD26VE REF - SXS/I&W
Amana SRD26VL REF - SXS/I&W
Amana SRD26VPE REF - SXS/I&W
Amana SRD26VPSE REF - SXS/I&W
Amana SRD26VW REF - SXS/I&W
Amana SRD27S2E REF - SXS/I&W
Amana SRD27S2L REF - SXS/I&W
Amana SRD27S2W REF - SXS/I&W
Amana SRD27S4E REF - SXS/I&W
Amana SRD27S4L REF - SXS/I&W
Amana SRD27S4W REF - SXS/I&W
Amana SRD27TPE REF - SXS/I&W
Amana SRD27TPSE REF - SXS/I&W
Amana SRD27TPW REF - SXS/I&W
Amana SRD325S5E REF - SXS/I&W
Amana SRD325S5L REF - SXS/I&W
Amana SRD325S5W REF - SXS/I&W
Amana SRD327S3L REF - SXS/I&W
Amana SRD327S3W REF - SXS/I&W
Amana SRD520SE REF - SXS/I&W
Amana SRD520SL REF - SXS/I&W
Amana SRD520SW REF - SXS/I&W
Amana SRD520TE REF - SXS/I&W
Amana SRD520TW REF - SXS/I&W
Amana SRD522SW REF - SXS/I&W
  #2 (permalink)
Old 05-16-2010, 10:18 AM
Junior Member
carriagehouse is on a distinguished road
Default
JE
I just had this problem with my kenmore side by side, it was leaking water inside my freezer and freezing solid in the ice bin. I tried the same thing as you removing that tube and it didnt work. It turned out to be water valve that is in the rear of the fridge that your water line feeds into. And it opens and closes for the water going into the ice maker and when it goes bad it overflows .There is also a filter in it that you can clean..I just replaced it and it solved my problem.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
water leak in front of refrigerator when using water dispenser RichardCh Refrigerator & Freezer Repair 0 08-10-2009 11:29 AM
water leak in back from water line TRUSTART Refrigerator & Freezer Repair 1 04-05-2009 08:01 AM
Whirlpool Refrigerator Water Leak wrightmd11 Refrigerator & Freezer Repair 3 03-10-2009 06:28 PM
water leak on back of fridge into icemaker jan09 Refrigerator & Freezer Repair 0 01-29-2009 05:49 PM
Water puddling in Refrigerator and back froze timchi29 Refrigerator & Freezer Repair 6 11-30-2008 07:21 AM
