The existing sensor wire on the factory thermostat is threaded into a clear plastic tube and extended into a soffit that runs along the edge of the top of the refrigerator. The replacement thermostat sensor wire is bare. Is it necessary to thread the sensor wire through this tube? If it is, what is the best way to go about this? It seems as though it would be very difficult to do.
