Admiral system 2000 fridge is not cold enough. evaporator fan is running, took back off freezer compartment, small amount of frost on bi-metal. adjust defrost timer or thermostat and evaporator fan starts but no compressor start. when plugged in for a while compressor gets warm but not hot and lower fridge compartment is about 52deg F with thermo set at mid range. HELP?
