Discuss
Refridgerator leaks water
 in
Refrigerator & Freezer Repair
My refriderator leaks water from under the freezer door. It tends to accummulate in the seal material at the bottom
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Refridgerator leaks water
  #1 (permalink)
Old 07-03-2008, 06:56 AM
Rocky56 Rocky56 is offline
Junior Member
Rocky56 is on a distinguished road
Default Refridgerator leaks water
Model Number: FRS22ZRG   Brand: Frigidaire   Age: 5 - 10 years
My refriderator leaks water from under the freezer door. It tends to accummulate in the seal material at the bottom of the door. It doesn't appear to be a continual leak just every now and then there is a puddle under the door. I have taken the interior components of the door off but there is a foam insulator under it and I am afraid to remove it. There is a water and ice despencer on the outside of the door so I assumed a line was leaking in the door itself. I have also removed all the despencer components and everything seemed to be okay. Any help you can give would be appreciated.
Thanks,
Rocky
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 07-03-2008, 09:58 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Rocky,
Check if there is ice chunk on the freezer floor. If there is one then the problem is a clogged and/or frozen drain under the evaporator coils. You can use a hair dryer to defrost it.
Here are the break down diagrams for the Frigidaire refrigerator Model FRS22ZRGB1
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 07-05-2008, 02:57 AM
Junior Member
Smile
Quote:
Originally Posted by Gene View Post
Hi Rocky,
Yes there is ice at the bottom of the freezer floor. I will try and melt it and see if that stops the leak.
Thanks,
Rocky
  #4 (permalink)
Old 07-05-2008, 06:34 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Rocky,
Melting ice on the bottom would not solve the problem. You have to open the drain which is under the evaporator coils.
__________________
  #5 (permalink)
Old 07-17-2008, 05:01 AM
Junior Member
Default
Hi Gene,
Well I was able to melt and remove all the ice in the freezer compartment, cleaned the evaporator also. I also went to the back and heated and cleared the drain tube. All was well but within 3 days ice built up again and it started leaking. What else can I do to stop this permanently? The heat bar that goes around the evaporator does get hot, I accidently touched it, could that bar not be heating all the time?
Thanks for your help,
Rocky
  #6 (permalink)
Old 07-17-2008, 01:06 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Rocky,
Take a piece of 12GA wire. Remove all insulation. Wrap one end of the wire around the defrost heater (you called it "heat bar") and put the other end into the drain hole.
__________________
  #7 (permalink)
Old 07-17-2008, 09:43 PM
ibcunning ibcunning is offline
Junior Member
ibcunning is on a distinguished road
Default
Gene I have the same problem. I know this will be a stupid question but where is the evaporator/evaporator coils? Somewhere within the freezer itself, below the unit or do you have to take the back cover off? Thanks!!
  #8 (permalink)
Old 07-17-2008, 11:46 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
ibcunning,
What is the complete model number of the fridge?
__________________
  #9 (permalink)
Old 07-18-2008, 07:30 AM
Junior Member
Default
Gene,
I called my tenant to get the make and model information but he had trouble finding anything? He said there was a cursive (fancy) H emblem next to the ice/water dispenser in the door. Other than that I had him look inside both sides of the unit and he couldn't find anything. I can't believe there isn't more information somewhere??
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
leaks water budmanduck Washer Repair 7 08-12-2008 05:19 PM
GE Arctica Refridgerator, water tray leaking, and other questions Jason B Refrigerator & Freezer Repair 6 05-01-2008 09:06 PM
Leaks water rchildress2 Washer Repair 1 11-23-2007 10:52 AM
Water leaks Gustavo Washer Repair 0 11-23-2007 10:01 AM
refridgerator leaks water from inside kmape Refrigerator & Freezer Repair 1 07-30-2007 11:40 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
