| » no cooling on either side frezzer or refrig |
Model Number: ess25xgmbb Brand: GE Age: 5 - 10 years
ge side by side no cooling on either freezer side or refrig side air is blowing into freezerside condensor fan is turning compressor is cold i dont have any manuals or schematics.any ideas appreciated ,thanks,narocroc
Does the compressor run (vibrating)?
Here are the breakdown diagrams and Replacement parts for General Electric ESS25XGMBBB Refrigerator | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
hi gene,currently not on site of refrigerator .. the model no is actuallyess25xgmbww..will respond more early nest week..i'm not sure if compressor was vibrating or not..if it's not i guess its the compressor..if it is ?then what any ideas? thanks ,narocroc
I do not like any guessing. Post as much as possible descriptions on everything what is going on with the refrigerator and we will go from there.
__________________
Check for 120VAC at connector J7-9 orange wire to TERMINAL-J8 black wire at the main control board. Do you have 120VAC?If no, replace the main control board. If yes, the compressor has gone bad. If the refrigerator is less than 5 years old, the compressor can be under the warranty. You have to verify it with GE. - The main control board Part number: AP4436216 Gene.
__________________
[quote=Gene;220332]
Check for 120VAC at connector J7-9 orange wire to TERMINAL-J8 black wire at the main control board. Do you have 120VAC? If no, replace the main control board. If yes, the compressor has gone bad. If the refrigerator is less than 5 years old, the compressor can be under the warranty. You have to verify it with GE. - The main control board Part number: AP4436216 Ok, will check on thursday 5-20..thanks Gene..narocroc |
__________________
Hello Gene sorry for delay .after removing control board(and before ordering a new one) i found a cold solder joint on a componant on back of board(a dark spot0 moving componant resulted in movement of the solder connection an back of board .resoldered connection..frig is 40 degrees at 5 setting frezzer is 0 degrees ar 5 setting ..water and ice work ok . i lucked out i guess ..its been running fine since last post.( cold solder joint was not on any J7 or J8 connector..thanks again for saving me a lot of expense..respectfully, narocroc
| Display Modes | |
| Refridgerator And Frezzer Not Cooling | JSERVA987 | Refrigerator & Freezer Repair | 0 | 09-24-2009 11:34 AM |
| side by side frezzer will not stay closed | Absolutehome | Refrigerator & Freezer Repair | 3 | 06-08-2009 05:34 PM |
| Frezzer is Fine Refrig is Warm - Fan is running | Chrish | Refrigerator & Freezer Repair | 3 | 05-30-2009 11:18 AM |
| frezzer and refrigerator not freezing and cooling | pmbarnes1205 | Refrigerator & Freezer Repair | 0 | 08-08-2008 10:21 AM |
| side by side refrig not cooling | chilldad | Refrigerator & Freezer Repair | 1 | 11-21-2007 02:53 PM |
