my ice maker stop working,I can hear a humming sound coming from it and that about it. The water dispenser work so I'm not sure where to start. Any help would be appreciated.
:confused:
Gene, the ice maker, now the humming noise stop, it does not fill with water or do anything. Since I'm a mechanic of 28 years, my first impulse is to take it apart. The dispenser work find but since there no ice, nothing comes out. If I have a repair manual with a troubleshoot chart, then it wouldn't be a problem. I can check for volts and ohms, but without knowing the value, it doesn't do much good. Any help would be appreciated.
hamalon320
Hello Gene,
I never toke the ice maker out, I don't hear it humming anymore so I'm affraid something might be burned out. I will go home and look at the other thread you mention tonight see what happen.
Thanks Gene. Hamalon320
