andyp3
#1 Posted : Tuesday, July 1, 2008 7:55:01 AM(UTC)
andyp3
Recently the water through the door on our Amana side by side became erratic and it appeared that the water valve was failing. I replaced the valve with a new one and all works well. The problem is the very noticable plastic/chemical taste and smell in the water. I ran 5 gallons through the system after the install but the taste is still there and after a week has not dimished (including several additional attempts to purge the system). Is this normal? Is this harmful? What do I need to do to get this back to where the water is drinkable?
#2 Posted : Tuesday, July 1, 2008 8:45:50 PM(UTC)
Is there a water filter inside or behind the refrigerator? if there is one - how old is it? If there is no a water filter then you have to install one to improve taste of drinking water.
Water inlet valve can not affect taste of water.
andyp3
#3 Posted : Wednesday, July 2, 2008 3:28:09 AM(UTC)
andyp3
There is a new filter before the valve (this model does not have a built in). This is clearly the valve causing the taste, it was not there prior to replacement. It is a plastic/chemical taste. I would not expect something made for potable water to do this but it has and the question is how can I fix it or can I?
#4 Posted : Wednesday, July 2, 2008 10:48:41 AM(UTC)
Originally Posted by: andyp3 Go to Quoted Post
...This is clearly the valve causing the taste, it was not there prior to replacement. ...the question is how can I fix it or can I?
The only what I can say in such situation is: try to replace the water valve with another one.
P.S. I never seen such problem before.
