Discuss
Replacing ice maker flap
 in
Refrigerator & Freezer Repair
The flap for the icemaker is warped, so warm air is able to enter the freezer, causing frost to build
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Replacing ice maker flap
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 07-01-2008, 06:52 AM
thuhangha thuhangha is offline
Junior Member
thuhangha is on a distinguished road
Default Replacing ice maker flap
Model Number: gss22sgmabs   Brand: GE   Age: 5 - 10 years
The flap for the icemaker is warped, so warm air is able to enter the freezer, causing frost to build up on the part that delivers the ice. To replace the flap, must the entire freezer door be disassembled, or can only the front ice dispenser cover be disassembled? I'm not sure if I can do this myself, or if I need to call a repair person.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 07-01-2008, 08:04 AM
abadfish66's Avatar
abadfish66 abadfish66 is offline
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
Easy fix. You need to remove the panel for the ice/water. Slide a small screwdriver underneath the panel and it pops right off, there may be 1 screw at the bottom middle. Once that's removed, remove the 4 screws and pull the whole assembly out, and there you can see the flapper.
__________________
Who wants a chance to win $10,000 a week for the next 17 weeks? How about $250,000 if you have the most points after 17 weeks. The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!!
Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacing a broken ice maker auger JER General Talk 0 04-17-2008 02:54 PM
replacing new auger in ice maker pbright Refrigerator & Freezer Repair 1 03-05-2008 09:41 AM
replacing outlet valve for ice maker stanleyn Refrigerator & Freezer Repair 1 12-17-2007 07:02 PM
Ice Flap Stuck! Tom Lambertv Refrigerator & Freezer Repair 0 10-01-2007 04:12 PM
Dispencer "flap" sticking open mommom02 Refrigerator & Freezer Repair 0 08-31-2007 11:02 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
