condenser fan motor not working have 13vdc on both pins out. changed fan with new one still not working replaced that one also not working.:mad:
Your condensing fan motor blew out the motherboard in the back AP4436216. This is a new designed board, hopefully it will not fail again.
Used Alternate 13vdc Power Sourse To Test Fan Motors. Found Original Fan And Replacement Fan Defective.second Replacement Fan Tested Ok.installed In Frig. And Did Not Work.with Fan Installed Metered Both Red & Yellow Feeds One At 13v The Other Reading Less Than 4v. Reversed Red & Yellow Wires Fan Working And Frig.ok No Need To Replace Mother Board Yet.thank You Appliance Parts Pro. For Your Help And Speedy Replacement Of First Defective Fan Motor. Will Definitely Return For Parts In Future.retired Verizon Tech. Working On Kids Appliances
