Appliance Repair Forum
-   Refrigerator & Freezer Repair (http://forum.appliancepartspros.com/refrigerator-freezer-repair/)
-   -   no cooling, click then hum (http://forum.appliancepartspros.com/refrigerator-freezer-repair/93299-no-cooling-click-then-hum.html)
NOLTING 05-05-2010 01:36 PM
This is a side by side Admiral. It suddenly quit cooling. The evaporator fan works. There is a click by the compressor, then a hum, then nothing. Someone said I need a capacitor, someone else said no. Someone said I need a relay. Someone else said that I needed a "hard start".
Gene 05-05-2010 07:40 PM
Remove the rear cover. Remove the overload/relay (#4 on the diagram) from the compressor and shake it. If it makes a rattling sound, replace it.
If the new part would not solve the problem, then the compressor itself has gone bad.
- The overload/relay Part number: AP4009244
Here are the breakdown diagrams and Replacement parts for ADMIRAL ASD2120DRW Ref - SXS/I&W | AppliancePartsPros.com
ChristianNeff 09-29-2012 04:44 PM
Hello, I have a Admiral ASD2120DRW and I just had the overload/relay go bad (thing was rattling), so I replaced it. That was about 4 hours ago, and now the fridge side isn't getting cold. The freezer is freezing though.
Gene 09-29-2012 05:20 PM
4 hours is absolutely not enough for the fridge to cool down to the correct temperature. If it was completely defrosted then it needs about 24 hours.
ChristianNeff 09-29-2012 06:12 PM
I was kinda thinking the same thing, but since the freezer side got so cold so fast, I figured maybe something else burned out when the overload/relay burned up on Friday.
I will get back to you tomorrow about it.
