Discuss
Ice Maker Seems To Be Leaking
 in
Refrigerator & Freezer Repair
There Is Very Cold Water On The Floor In Front Of My Fridge,not A Lot. I Have Also Noticed
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Ice Maker Seems To Be Leaking
  #1 (permalink)
Old 06-29-2008, 01:10 PM
OLDLADYCAMPER OLDLADYCAMPER is offline
Junior Member
OLDLADYCAMPER is on a distinguished road
Default Ice Maker Seems To Be Leaking
Model Number: DRB1801AC   Brand: Amana   Age: 5 - 10 years
There Is Very Cold Water On The Floor In Front Of My Fridge,not A Lot. I Have Also Noticed That It Only Does This When The Icemaker Is In The Normal Position...in Other Words When The Arm Is Up It Does Not Leak. What Would Be The Problem. And Is It An Easy Fix? Any Help Will Be Appreciated.
Thank You,
Oldladycamper
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-29-2008, 01:22 PM
abadfish66's Avatar
abadfish66 abadfish66 is offline
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
First thing to check would be the floor of the freezer, does it have a layer of ice? Is there any evidence of the ice maker leaking, ie. icicles? Based on what you said, I would suspect the defrost drain as being clogged and frozen. And when it goes into defrost, about once a day the water will leak out your door.
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!!
Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up.
  #3 (permalink)
Old 06-29-2008, 02:15 PM
Junior Member
Default
You Were Right,the Floor Of The Freezer Was Full Of Ice. I Cleaned It Out. And Reset The Ice Maker Arm. I Will Wait And See If It Will Make Ice Or Not. As For The Other,where Would I Lookto Find Where It Might Be Clogged? There Does Not Seem To Be A Drain Pan On This Model Of Fridge.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Profile Arctica Ice Maker Leaking clobdell Refrigerator & Freezer Repair 4 03-22-2008 07:37 AM
Ice Maker water leaking pothole914 Refrigerator & Freezer Repair 0 01-13-2008 08:49 AM
Ice maker leaking Michael L Refrigerator & Freezer Repair 0 10-20-2007 01:21 PM
ice maker leaking but still making ice Brian Refrigerator & Freezer Repair 1 09-28-2007 03:47 AM
Ice maker still leaking - Just replaced fill valve Adam80 Refrigerator & Freezer Repair 1 09-12-2007 08:09 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
