Discuss
Request help for Kitchenaid stand alone ice maker
 in
Refrigerator & Freezer Repair
New to the forum here, as I try and find an answer. I have a 3 year old Kitchenaid Icemaker.
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Request help for Kitchenaid stand alone ice maker
  #1 (permalink)
Old 06-29-2008, 08:39 AM
ran007 ran007 is offline
Junior Member
ran007 is on a distinguished road
Default Request help for Kitchenaid stand alone ice maker
Model Number: KUIA15PRLS2   Brand: Kitchen Aid   Age: 1 - 5 years
I have a 3 year old Kitchenaid Icemaker. Couple of days ago, it stopped making ice, or really really poor ice. I pulled it out, cleaned out the dust from the condenser, even put some cleaner and ran it on clean mode for a couple hours. After cleaning it up last night and leaving it out from under the counter to access cooler air, I set it to run overnight, expecting a full ice bin this morning. I wake up, and no ice. Its running and the condenser toward the front is really hot.
Here are some facts. The water resevior fills fine. The circulation pump that moves the water over the evaporator is doing fine. The cutting grid has the correct voltage. We had a pretty bad storm come through which fried our computer... The storm may be the cause?
So here's were it gets funny. When the freeze cycle starts, the condenser fan runs and draws a very good amount of air, but only for a minute then turns off. So I can imagine if the fan doesn't run, then the condenser doesn't get cold, and the evaporator doesn't get cold. Doesn't the compressor relay and overload control this function, and could it have been damaged in the storm?
I unplugged it from AC, and pulled the relay and overload modules off and took a closer look. They don't smell bad, or seemed burned. So is it possible the compressor relay and overload modules are bad? Could it be both, or one or the other? ...Or could it be the fan motor?
Much appreciate any help!
Randall
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 07-03-2008, 06:54 PM
Junior Member
Default
I ordered a new relay - it's got some loose parts inside when I shake it, which I don't think is normal... I'll let you guys know what happens when I put it on.
  #3 (permalink)
Old 07-16-2008, 11:37 AM
no1hog no1hog is offline
Junior Member
no1hog is on a distinguished road
Default
Did you have any luck with your problem yet?
  #4 (permalink)
Old 07-16-2008, 11:48 AM
Junior Member
Default
No luck - I ordered the relay, then when it came in the bag was already opened and taped back which made me a little suspicious... I notified customer service the second it came in, but after a week I still haven't heard back from them. Beware I guess. I would have ordered other parts to troubleshoot, but if this is how they work, then I'll go somewhere else I guess.
I put a meter on the original relay and the overload. They test out good. The compressor even shows the correct resistance. So I put in a call to Kitchenaid, hoping the 2-5 yr warranty will cover the problem and maybe they'll determine that the sealed portion has failed.
any ideas? or do you have the same problem?
  #5 (permalink)
Old 07-16-2008, 11:56 AM
Junior Member
Default
Have you had anyone suggest the reversing valve might be bad? I have a similar problem. Also, I don't know if you can change the solenoid reversing valve without breaking into the refrigerant.
  #6 (permalink)
Old 07-16-2008, 04:14 PM
Junior Member
Default
Good point on the reverse valve - and if that's part of the sealed system, then it will be covered in the 2-5 yr warranty. Thanks for the advice. I'll tell the repair guy on Friday that it may be a point of interest.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchenaid ice maker bryan b General Talk 4 08-25-2008 01:18 PM
Kitchenaid Icemaker JTSchrock Refrigerator & Freezer Repair 0 06-20-2008 12:18 PM
stand alone icemaker Ec5100 Don Brackett General Talk 1 02-01-2008 12:45 PM
Ice maker issues Kitchenaid pezley69 Refrigerator & Freezer Repair 9 01-09-2008 01:15 PM
Request for directions on installing part csjarboe012@aol.com Refrigerator & Freezer Repair 1 12-28-2007 03:27 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
