| » Evaporator keeps freezing over |
Model Number: RS2630SH Brand: Samsung Age: 1 - 5 years
I have read that this is a fairly common problem with these SAMSUNG refrigerators. Came home from vacation a few weeks back to find everything warm in both freezer and refrigerator compartments. Found evaporator coils completely frozen over. Coils defrosted when I unplugged unit and was cleaning out all the lost food - after plugging back in everything worked o.k. but coils will re-freeze about every 4-5 days (I'll unplug, defrost manually and go through it all again). Seems like unit is not going through the defrost cycle correctly, but I haven't gotten much help / advice from the folks at SAMSUNG (unit is about 4 months out of warranty). I have read on some posts the most likely cause is the PBA main circuit board, but wondered if I should start with replacing some of the lesser expensive potential culprits / parts first. Any advice is greatly appreciated (also, is there any special procedure to replacing the PBA main). Thanks for any help.
i would ohm check the heater and the thermal fuse. if either is open bad part if both are good bad relay on PCB
__________________
J&D Appliance Repair Serving Pendleton County, Kentucky and Surrounding Areas |
| Display Modes | |
| evaporator fan | username | Refrigerator & Freezer Repair | 5 | 06-29-2008 11:07 AM |
| Evaporator fan? | Shady | Refrigerator & Freezer Repair | 12 | 06-05-2008 07:07 AM |
| GE refridgerator Freezing food in Fridge and freezing water line | niloa | Refrigerator & Freezer Repair | 0 | 04-09-2008 09:59 AM |
| Evaporator Motor | GaryDolman | Refrigerator & Freezer Repair | 5 | 01-15-2008 10:49 AM |
| Sub Zero 201 FD Freezer is not freezing and coils are frosting over/freezing up | badace | Refrigerator & Freezer Repair | 1 | 12-02-2007 10:54 AM |
