Discuss
Side By Side Not Cooling/ Fan Not Running At All
 in
Refrigerator & Freezer Repair
Hello all..i have a side by side refrigerator,a few months ago i've noticed everything in the freezer
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Side By Side Not Cooling/ Fan Not Running At All
  #1 (permalink)
Old 06-27-2008, 09:50 AM
slyda slyda is offline
Junior Member
slyda is on a distinguished road
Default Side By Side Not Cooling/ Fan Not Running At All
Model Number: GSS25JFMCWW   Brand: GE   Age: 5 - 10 years
Hello all..i have a side by side refrigerator,a few months ago i've noticed everything in the freezer defrosted and it does not stay cool,the evaporator fan stopped running, ice maker stopped working,coils would have a lot of frost on them from the bottom to middle,i replaced the evaporator fan but still no luck with it.. i figured because the freezer is not cool enough the ice maker does not work?? any ideas on how to go about this problem guys? thanks.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-27-2008, 09:57 AM
abadfish66's Avatar
abadfish66 abadfish66 is offline
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
If your fan stopped running and you replaced it and still not running, your going to need the main control board located on the back of the unit behind an access panel.
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!!
Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up.
  #3 (permalink)
Old 06-27-2008, 08:37 PM
Junior Member
Default
ok and that will fix the ice maker problem and the cooling problem rite? also is it a hard task to remove that board cause i see some white tabs are holding it down..and how much should i expect to pay for it, thanks alot for ur help
  #4 (permalink)
Old 06-27-2008, 09:28 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
Yes that will fix all the problems you have. Sqeeze the tabs with needlenose pliers, comes right off. The board runs between $100 and $140...Keep me posted
__________________
  #5 (permalink)
Old 07-03-2008, 09:09 PM
Junior Member
Default
Ok i bought the board... i must say its not the same exact one... it has some more added parts on it such as..Pan/Htr Relay... J12 Connection, J5 connection,when i installed it... the fan started running slow... the freezer section is not yet closed up.. i still have it opened.. is something else wrong making the fan spin so slow? or does it have to settle in? thanks.
  #6 (permalink)
Old 07-03-2008, 11:30 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
Yes, the board looks different, but is the same. It's universal for several different models. Give it time to adjust temp wise, you'll be good
__________________
  #7 (permalink)
Old 07-04-2008, 12:30 AM
Junior Member
Default
Ok thanks.. ill keep u posted about what happens by tomorrow..thanks again!
  #8 (permalink)
Old 07-04-2008, 01:23 AM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
Did you look at the instructions to find out if you needed to cut the wire described on the instruction sheet.
__________________
  #9 (permalink)
Old 07-04-2008, 10:22 AM
Junior Member
Default
Hm.. it did not come with any instructions... i bought the board off of **** from a seller who obtained the part from best buy.. i did not see any instructions in the box...i think i have to do something more to it cause the freezer fan is constantly running at a mid speed and it wont stop.. freezer is cold now. is their anything i should check out?
  #10 (permalink)
Old 07-04-2008, 11:46 AM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
The fan will continue to run about 80% of the time, it is fine. What is the freshfood temp, is it cooling? if so you are good to go.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
side by side ice and water in door not cooling or freezing Anna1441 Refrigerator & Freezer Repair 0 06-26-2008 08:11 AM
Side by side fridge running warm rkaulback Refrigerator & Freezer Repair 5 05-29-2008 08:18 PM
side by side refrigerator stopped cooling and freezing bbcowboy Refrigerator & Freezer Repair 3 03-21-2008 07:02 PM
Amana side by side freezer not cooling gunner Refrigerator & Freezer Repair 1 12-03-2007 04:30 PM
Kenmore Side by Side - Fridge Not Cooling pharmaman Refrigerator & Freezer Repair 3 10-11-2007 05:45 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
