The ice maker was not filling with water, so I repleaced the water value assembly. There are 2 wire connectors that connect to the solenoids within the water value assembly, 1 purple and one brown. The wire harnesses have one purple or brown wire as well white wires. Do the purple/brown wires face towards the center or the water value assembly or towards the outside of the water value asembly? I am getting water through the door water dispenser as I should, however the ice maker has not yet filled with water and it has been 24 hrs since I installed it. Please advise, Thanks Kevin
