Discuss
evaporator fan
 in
Refrigerator & Freezer Repair
Second fridge in the basement. Fridge not very cool, but freezer works. Freezer coils have some frost and one corner
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » evaporator fan
  #1 (permalink)
Old 06-24-2008, 07:27 PM
username username is offline
Junior Member
username is on a distinguished road
Default evaporator fan
Model Number: KTRS20MAWH01   Brand: Kitchen Aid   Age: More than 10 years
Second fridge in the basement. Fridge not very cool, but freezer works. Freezer coils have some frost and one corner had large ice chunk that I removed. Evaporator fan not appear to be working and nothing block it. Door switch works and still does not activate fan. Also have water drips forming on ceiling of the inside fridge. For 1993 second fridge is it worth trying to replace fan or possible main control board. Is that the correct diagnosis? Or am I better off junking and buying new.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-25-2008, 06:56 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Remove the rear cover and check if the compressor and the fan next to it are running. Post your findings.
Here are the break down diagrams for the Kitchen Aid refrigerator Model KTRS20MAWH01
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 06-25-2008, 09:11 PM
Junior Member
Default Evaporator Fan
Yes, the compressor and fan are running.
  #4 (permalink)
Old 06-25-2008, 09:22 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Clean the condenser coil (#3 on the unit break down diagram), wait about 24 hours and check temperatures inside both compartments. Post your findings.
__________________
  #5 (permalink)
Old 06-28-2008, 12:20 PM
Junior Member
Gene, It was pretty dirty and I vacummed it out from the front and the back. The temp in the fridge after 24 hours is still warm at 53.2. The freezer was on the coldest setting and it got down to -20 when I reset it to the middle setting and stopped measuring. What next?
  #6 (permalink)
Old 06-29-2008, 11:07 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Remove evaporator fan wires and stick 115 volts to the fan motor and see if it runs. If so, you will need a voltmeter to find the problem, might be a bad door switch.
If not, order a new evaporator fan.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Evaporator fan? Shady Refrigerator & Freezer Repair 12 06-05-2008 07:07 AM
evaporator fan speed seems to very brad_rice Refrigerator & Freezer Repair 0 04-17-2008 06:09 PM
Evaporator snowed in caseym Refrigerator & Freezer Repair 3 11-30-2007 03:43 PM
Evaporator fan not working tony51 Refrigerator & Freezer Repair 5 10-26-2007 05:26 PM
evaporator fan problems csteven Refrigerator & Freezer Repair 1 07-25-2007 03:25 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
