| » Help Help Help |
Model Number: GSS22SGPCSS Brand: GE Age: 1 - 5 years
I have a problem with my refrigerator. It works great until frost comes up on the back panel of the freezer and then it slowly stops working. First the icemaker stops making ice and then the fridge part of it stops getting cool and then I have to unplug it and let it defrost and usually within 24 hours I can plug it back up and it will work for a few days until the cycle starts all over again with the frost on the back panel. I took the back off of the refridgerator and everything seems to be working ok. I took the drain tube off and made sure nothing was clogging it up and it looks fine so I am not sure what to do. It doesn't look like there are too many things back there that can be replaced so it's probably easy to repair but I don't know where to start. Any suggestions?
You have a defrost problem, your heater is not coming on to defrost the evap. Do you have a meter to test for continuity of the heater?
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!! Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up. |
You will need to remove the back panel of the freezer section, once removed, you will see the heater at the bottom of the evap. Take the 2 screw out that hold the heater on, remove the wires, and check if heater is good. if not you will need to order a new heater, if heater is good we'll procede to the next steps. here is the part# to order the heater if it's bad AP4355467
__________________
I took the back panel off of the refrigerator but all I see are a few parts and nothing that looks like the part you described as the heater. I am think it might be behind the coil <--not sure if thats the right name of it, but it looks like a round radiator that has a fan blowing on it. I can't remove that because it has welded parts in front that would have to be broken in order to get it out.
It is in the freezer section, remove all shelves, remove back panel, 2 screws up top and 2 at the bottom, and there is your evaperator. now at the bottom of the aluminum evap is your heater.
__________________
| Display Modes | |
