Discuss
Freezer & Fridge not cold
 in
Refrigerator & Freezer Repair
I recently aquired this fridge. it worked great for about 2 weeks then it started getting warm inside. The ice
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer & Fridge not cold
  #1 (permalink)
Old 06-24-2008, 02:39 PM
Tye Tye is offline
Junior Member
Tye is on a distinguished road
Default Freezer & Fridge not cold
Brand: GE   Age: 5 - 10 years
I recently aquired this fridge. it worked great for about 2 weeks then it started getting warm inside. The ice cream not freezing. I did some online searching and decided to change the defrost timer. This has had no effect. Here is what I can tell you about the fridge.
The coils in the back of the freezer are freezing up.
The fan in the freezer is working constantly.
The condenser is HOT.
The condenser fan is running.
The defrost timer is new.
The temp is 46 in the fridge and 34 in the freezer.
What do I do now?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-24-2008, 02:47 PM
abadfish66's Avatar
abadfish66 abadfish66 is offline
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
When you say the coils in the back of the freezer is freezing up, does that mean you have like compacted snow on the coil, or do the coils have a light coating of frost?
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!!
Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up.
  #3 (permalink)
Old 06-24-2008, 02:50 PM
Tye Tye is offline
Junior Member
Default
I has light to thick frost and the begining of ice chunks. If I advance the defrost timer until it clicks, should the defrost elaments heat up?
  #4 (permalink)
Old 06-24-2008, 02:53 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
Yes, as long as the defrost termination thermistat is cold enough. You did not include the model#, but does this have the 2 defrost heaters one on the very bottom of coils, and one in about the middle, if so check the bottom element for burnout if the heaters don't come on when advancing the timer to defrost
__________________
  #5 (permalink)
Old 06-24-2008, 02:56 PM
Tye Tye is offline
Junior Member
Default
Yes it has the dual heaters.
I don't know the model number. It is nowhere inside the fridge.
So I advanced the defrost timer until it clicked and neither of the elements are heating up.
  #6 (permalink)
Old 06-24-2008, 03:01 PM
Tye Tye is offline
Junior Member
Default
So I just advanced the defrost timer around again and finally for the first time in days the fridge fans and everything turned off. However the heating elements are still cold.
  #7 (permalink)
Old 06-24-2008, 03:03 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
If your coils are covered in heavy frost, and you heaters don't come on, chances are you heaters are bad, can you do a continuity check on the heater?
__________________
  #8 (permalink)
Old 06-24-2008, 03:04 PM
Tye Tye is offline
Junior Member
Default
I can stick my fingers on the wires and see if I get shocked, if that is what you mean?
  #9 (permalink)
Old 06-24-2008, 03:18 PM
Tye Tye is offline
Junior Member
Default
I hope I didn't offend you. I am not sure what this test is that you are talking about. I can tell you that the fridge is still powered down and the heaters are still cold and the fridge and freezer are not cold.
  #10 (permalink)
Old 06-24-2008, 03:25 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
Takes alot to offend me Continuity check means taking a meter and checking if a wire is good or bad.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
freezer at 30 fridge not cold enough tmo Refrigerator & Freezer Repair 0 02-19-2008 07:49 AM
Fridge & freezer not cold balzywitch Refrigerator & Freezer Repair 1 01-01-2008 08:19 PM
fridge&freezer no cold air notemp Refrigerator & Freezer Repair 1 11-02-2007 04:37 AM
freezer cold but not freezing, Fridge is ok USMCret. Refrigerator & Freezer Repair 5 10-27-2007 07:31 PM
Fridge & Freezer Cycle Cold To Warm Back To Cold terkel Refrigerator & Freezer Repair 1 09-25-2007 03:58 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
