| » GE Profile Fridge - Freezer icing like lava |
Model Number: TCD18PADAAA Brand: GE Age: 1 - 5 years
Every 30 days I have to remove all the food in the (pull-out drawer) freezer and chop away ice build-up. The ice seems to flow like lava from the top of the rear wall of the freezer and then spread out across the floor of the freezer. A month of build up is so significant that getting the freezer drawer to open and close is a real chanllenge. Can you suggest a fix? Thanks.
The easiest way to take care of this problem would be to unplug the unit and let it defrost overnight. What you have is a defrost drain tube that is frozen up, I can give you instruction on how to fix, you will need to take the bottom of the freshfood section apart, let me know which way you want to fix this.
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!! Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up. |
Thanks for the reply. I would like to give this a permanent fix if I could, so taking the bottom off the fresh food section is not a problem for me. If you could pass along the remaining steps, that would be great. Thanks!
WE nee to determine what is at fault, so remove the bottom of the refer section, should be 2 screws in the front, but not the 2 screws facing you. you will need to pry up at the front of the bottom plastic cover until it is out, and pull it out of there. It is kinda difficult, but it does come out. Next take out the styrofoam cover and tell me what you see, is it heavy frost, or thick ice in there?
__________________
| Display Modes | |
| freezer icing problem | carlos p | Refrigerator & Freezer Repair | 3 | 06-26-2008 12:20 AM |
| freezer icing problem | billinaz29 | Refrigerator & Freezer Repair | 4 | 04-07-2008 04:44 PM |
| fridge drain icing up | dlucas | Refrigerator & Freezer Repair | 0 | 03-31-2008 03:54 PM |
| Freezer is icing up. | mikeschneider | Refrigerator & Freezer Repair | 0 | 10-11-2007 10:48 AM |
| freezer coils icing up | hchmeyer | Refrigerator & Freezer Repair | 0 | 09-06-2007 11:15 AM |
