Discuss
Under Counter Ice Maker Will Not Go Into Icemaking Cycle
 in
Refrigerator & Freezer Repair
I have an under the counter Kenmore icemaker that came with a house we purchased, the icemaker is about 4
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Under Counter Ice Maker Will Not Go Into Icemaking Cycle
  #1 (permalink)
Old 06-22-2008, 08:39 AM
drowe30 drowe30 is offline
Junior Member
drowe30 is on a distinguished road
Default Under Counter Ice Maker Will Not Go Into Icemaking Cycle
Model Number: 106.894483994   Brand: Kenmore   Age: 1 - 5 years
I have an under the counter Kenmore icemaker that came with a house we purchased, the icemaker is about 4 years old. After we moved in I cleaned the icemaker, fixed the cutting grid and it worked OK for a while.
We had a bad thunderstorm a few months ago with a couple of power surges and the unit stopped working completely. I replaced the main water pump and the control board last week. When I first turned the unit back on the water reservoir filled up, the main recirculating pump kicked on for about a minute and then shut off. The water reservoir keeps filling overflows into the hopper and the drain pump kicks on.
I turned the unit off, than tried the cleaning cycle. The main recirculating pump did turn on, the water circulated and heated up. The unit ran over an hour, past the 45 minute cleaning cycle, so I turned it off.
I drained the water, turned it on, the reservoir fills up but the main pump will not run for a normal ice making cycle.
I called the Sears repair guy, he showed up and I knew more about how the icemaker worked than he did. I sent him on his way.
What I know works:
1. Inlet valve
2. Drain pump
3. Main pump in cleaning cycle
4. Heating Cycle
What would prevent the unit from going into the ice making cycle???
One person suggested that it might be the reversing valve on the refrigeration system?
If I replaced the valve would I need to re-service the unit with refrigerant? Any other suggestions?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 07-16-2008, 11:47 AM
no1hog no1hog is offline
Junior Member
no1hog is on a distinguished road
Default
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
  #3 (permalink)
Old 07-16-2008, 11:49 AM
Junior Member
Default
I think I have the same problem. Did you determine if the reversing valve was an issue and whether or not you had to break into the refrigerant line to replace it? Thanks
  #4 (permalink)
Old 07-16-2008, 03:44 PM
Junior Member
Thumbs up It Was Not the Reversing Valve
I found a guy near me that works on ice machines and broke down and took it to him. It was not the reversing valve, in-between the drain tank and the drain pump there is a screen filter in the drain line that was clogged. If the drain tank fills up and does not drain, there is a float switch that prevents the unit from going into the ice making cycle. There is no warning or suggested cleaning or checking in the owners manual !!!
To check the screen and line, go behind the unit, on the bottom is a black plastic tank that is held in by a bracket with two screws. Unscrew the bracket and remove the black tank and you will see the drain line screen filter, it is about the size of a garden hose line. It is a bit of a pain getting the clamp back on when you are done, I would suggest that you replace the spring hose clamp with a better screw type hose clamp.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ice Maker only makes ice during cleaning cycle. LH1 Refrigerator & Freezer Repair 4 07-16-2008 11:52 AM
Washer fills on wash cycle and rinse cycle and won't stop filling! riphinney Washer Repair 15 03-12-2008 06:30 PM
Hotpoint Counter Saver Plus dalejennemma Heating, Ventilation, and Air Conditioning (HVAC) 0 01-05-2008 09:21 AM
Dishwasher skips the wash cycle and stops at the rinse cycle jasporo Dishwasher Repair 1 11-16-2007 06:12 PM
How do I remove my trash compactor, so I can change counter monicaacevedo Garbage Disposer Repair 3 11-06-2007 12:47 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
