| » Frigidaire Cooling Fan Question |
Hi Ron,
The fan direction should be viewed from rear of the motor, but you do not have to do it as long as the new motor has the same CW (or CCW) matching "stamp". There is no polarity for 120VAC motor what means you can connect wires in any direction. Compressor and fan motor are operated by two devices: defrost timer and temperature control. Defrost timer switches power between defrost system and cooling system (compressor, condenser fan, e.t.c.) based on time intervals i.e. 10 hours "cooling system" - 25 minutes "defrost system". While cooling system is powered "on", temperature control maintains a certain temperature by turning cooling system "on" and "off". Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Hello Gene,
Thanks a ton for the info. I would guess that the defrost time that I had to replace on this same fridge a few years back would be the device that controls that time interval. Our "no frost" freezer was frosting up and the advice at the time was to make a mark on the timer wheel and check back and see if it moved and in my case it didn't. It's the time that is located at the front left bottom. Anyway, back to the present case at hand, I have had the back off of it and pushed out from the wall to keep an eye on things and all looks well and so I am going to button it up. Thanks again for all your assistance and sharing of your knowledge to guys like me that have the ability to perform the task, just not the knowledge. Ron |
You're welcome, Ron. Have a good day.
__________________
| Display Modes | |
| Frigidaire Question | madyz360 | Refrigerator & Freezer Repair | 1 | 07-08-2009 08:20 AM |
| Frigidaire S by S not cooling/freezing | tahoe437 | Refrigerator & Freezer Repair | 1 | 03-14-2009 08:36 PM |
| frigidaire syphone tube question | kevbayer | Washer Repair | 1 | 03-09-2009 01:23 PM |
| Frigidaire Freezer not cooling | Ken TN | Refrigerator & Freezer Repair | 1 | 04-28-2008 03:47 AM |
| Frigidaire fridge not cooling after an hour or so | labtec | Refrigerator & Freezer Repair | 0 | 08-14-2007 01:11 PM |
