Discuss
Air Diffuser replacement
 in
Refrigerator & Freezer Repair
I have: Kenmore side by side refrigerator model 106.52609100 Air diffuser part # (from the Sears electronic diagnostic sheet) 2216112
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Air Diffuser replacement
  #1 (permalink)
Old 06-19-2008, 01:24 PM
g20zoom g20zoom is offline
Junior Member
g20zoom is on a distinguished road
Default Air Diffuser replacement
Model Number: 106.52609100   Brand: Kenmore   Age: 5 - 10 years
I have:
model
106.52609100
2216112
Freezer works fine but fridge is only 55-60 degress. The Air diffuser is closed. I forced it open, but it ends up closing when I come back to it. I just read from this forum i might need to disconnect the wires, i'll try that.
Fridge was working fine last week, until I moved it...it was shutoff for about 10-15 minutes, so after that...fridge was busted.
Does it sound like a bad air diffuser or is the part just need to be cleaned/defrosted? Do you think the warmer air(when unplugged) caused some ice to melt then refreeze and lock up the vent?
In any case, I just ordered a part from here. Does anyone know if the part # above also includes a thermistor in there?
Lastly, how do I go about replacing the unit?
Here's what I think needs to be done:
fridge side - remove wiring cover screw and another screw on the air diffuser.
freezer -remove ice maker, air shute? and get to the back of the diffuser to push it out on fridge side.
I know there are 2 prongs on the diffuser, but i'm not sure how that will be handled yet.
Thanks!!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-20-2008, 12:43 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem is a bad air diffuser. It comes without a thermistor.
You described the replacement procedure absolutely right, but if you need the complete diagnosis and installation instructions, you can find them in the service manual.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 06-20-2008, 03:12 PM
Junior Member
Default
Thanks Gene. Excellent pictures in the manual. Identical pics to the fridge. It's crystal clear after I poked around in there last nite. Just received the part too, so I'll try it out tonite. Saves me $100 on labor if this solves the problem!
  #4 (permalink)
Old 06-20-2008, 05:20 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Keep us posted.
__________________
  #5 (permalink)
Old 06-23-2008, 10:54 AM
Junior Member
Default
It seems to be working. When I had the diffuser partially blocked open with a stick, it took a few hours to come down from 55-60 deg to 40. With the new part in, temp was down to 40 in an hour or so. In the morning it was about 37 deg or so but daytime it doesn't really go lower than 40.
Question, digital temp on the fridge side says 33. That's the lowest setting but fridge only comes down to 40. Freezer is at 0 last week when I checked. Outside fridge temp is about 80-85 degrees during the day. Should my fridge be getting colder?
  #6 (permalink)
Old 08-11-2008, 01:10 PM
jonlmiller jonlmiller is offline
Junior Member
jonlmiller is on a distinguished road
Default
i've had lot's of problems with the diffuser, and have just finally ordered a new one. what i've found is that if a door is left ajar, (can't remember which one), then the diffuser ices up. once the part with the slots in it insider the deffuser is frozen in place, then the cam that moves it (with quite a bit of torque) breaks the sliding part. i've rebuilt that bit a few times, but it looks like it failed again.
  #7 (permalink)
Old 08-11-2008, 05:02 PM
Junior Member
Default
How did you repair it the past? I used a new part...so far, it's working pretty good. I did save my old part to dissect when I get some free time. Looking in the vents though, it seems fine.
  #8 (permalink)
Old 08-11-2008, 05:23 PM
Junior Member
Default repairing the diffuser
i'll post some pictures of the old, frequently repaired one as soon as the new one arrives. i only repaired it as a challenge to myself -- it was NOT worth it except for the amusement factor. the first time it failed, i called for warranty service. the guy came out, stuck a screwdriver in the vents, and got it open again, so the fridge cooled down. but he probably broke it further by doing so and it failed again within weeks. after that, it was just me against the establishment!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
diffuser drips water into refrigerator squigoth Refrigerator & Freezer Repair 4 05-29-2008 03:12 PM
air diffuser McFrank Refrigerator & Freezer Repair 2 09-29-2007 07:35 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
