Discuss
LG Refrigerator - freezer has ice collecting at bottom
 in
Refrigerator & Freezer Repair
Have had this peculiar problem with our LG refrigerator for the past year. The bottom loading freezer gets a collection
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » LG Refrigerator - freezer has ice collecting at bottom
  #1 (permalink)
Old 04-19-2010, 11:59 AM
Junior Member
lgrefrig is on a distinguished road
Default LG Refrigerator - freezer has ice collecting at bottom
Model Number: LRBN225255W   Brand: -other-   Age: 5 - 10 years
Have had this peculiar problem with our LG refrigerator for the past year. The bottom loading freezer gets a collection of ice at the bottom of the freezer which I have to take out about every 2 weeks. Do not have an ice maker. Have called LG and they just state that I need a repair person to look at. The settings for the refrigerator and freezer are normal and food stays fresh in refrigerator and in freezer food is frozen as normal. I've vacuumed underneath the refrigerator. What gives?
Related Models
 LRE30451SB Electric Range
 LRE30451ST Electric Range
 LRE30451SW Electric Range
 LRE30755SB Electric Range
 LRE30755ST Electric Range
 LRE30755SW Electric Range
 LRE30757SB Electric Range
 LRE30757ST Electric Range
 LRE30757SW Electric Range
 LRE30955ST Electric Range
 LRFC21755SB Refrigerator
 LRFC21755ST Refrigerator
 LRFC21755TT Refrigerator
 LRFC22750ST Refrigerator
 LRFC22750SW Refrigerator
 LRFC22750TT Refrigerator
 LRFC25750SB Refrigerator
 LRFC25750ST Refrigerator
 LRFC25750SW Refrigerator
 LRFC25750TT Refrigerator
 LRFC25750WW Refrigerator
 LRFD21855ST Refrigerator
 LRFD25850SB Refrigerator
 LRFD25850ST Refrigerator
 LRFD25850SW Refrigerator
 LRFD25850TT Refrigerator
 LRFD25850WW Refrigerator
 LRG30355SB Gas Range
 LRG30355SW Gas Range
 LRG30357ST Gas Range
 LRG30855ST Gas Range
 LRM1230B Microwave Oven
 LRM1230W Microwave Oven
 LRM1250B Microwave Oven
 LRM1250W 01 Microwave Oven
 LRM1260SW Microwave Oven
 LRM2060ST Microwave Oven
 LRMM1430SB Microwave Oven
 LRMM1430SW Microwave Oven
 LRMP1270ST Microwave Oven
 LRSC21934SB Refrigerator
 LRSC21934SW Refrigerator
 LRSC21934TT Refrigerator
 LRSC21935SB Refrigerator
 LRSC21935TT Refrigerator
 LRSC21951ST Refrigerator
 LRSC26910SW Refrigerator
 LRSC26910TT Refrigerator
 LRSC26911SW Refrigerator
 LRSC26911TT Refrigerator
 LRSC26912SW Refrigerator
 LRSC26912TT Refrigerator
 LRSC26915SW Refrigerator
 LRSC26920SB Refrigerator
 LRSC26920SW Refrigerator
 LRSC26920TT Refrigerator
 LRSC26922SW Refrigerator
 LRSC26922TT Refrigerator
 LRSC26923SW Refrigerator
 LRSC26923TT Refrigerator
 LRSC26925SW Refrigerator
 LRSC26925TT Refrigerator
 LRSC26930SW Refrigerator
 LRSC26930TT Refrigerator
 LRSC26940ST Refrigerator
 LRSC26940TT Refrigerator
 LRSC26941SB Refrigerator
 LRSC26941ST Refrigerator
 LRSC26941SW Refrigerator
 LRSC26944SW Refrigerator
 LRSC26944TT Refrigerator
 LRSC26960TT Refrigerator
 LRSC26980SB Refrigerator
 LRSC26980TT Refrigerator
Maytag LRSD20A REF - SXS
 LRSPC2031BK Refrigerator
 LRSPC2031BS Refrigerator
 LRSPC2031T Refrigerator
 LRSPC2051ST Refrigerator
 LRSPC2331BS Refrigerator
 LRSPC2331W Refrigerator
 LRSPC2661T Refrigerator
 LRTB2023BS Refrigerator
Maytag LRTD17A REF - TOP MOUNT
Maytag LRTD19A REF - TOP MOUNT
Maytag LRTD23A Ref - Top Mount
 LRTN09314SW Refrigerator
 LRTN19310BQ Refrigerator
 LRTN19310WW Refrigerator
 LRTN19311SW Refrigerator
 LRTN22310SW Refrigerator
 LRTN22310TT Refrigerator
 LRTN22310WW Refrigerator
 LRTN22311TT Refrigerator
 LRTPC1831T Refrigerator
 LS-K2430CL Air Conditioner
 LS-K2430HL Air Conditioner
 LS-L1210CL Air Conditioner
  #2 (permalink)
Old 04-20-2010, 03:12 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
As with most LG's I could not find any info on this unit.
Perhaps the following will be of some use
http://136.166.4.200/contents/Fridge...ice_Manual.pdf
Sounds like the drain tube going from under the evaporator coils to the drip tray under the unit is plugged.
Check that there is not dust etc. blocking it at the drip tray end.
If OK
Remove the evaporator cover and blow it clear.
If you have a compressor you can use it set at a low pressure OR push a flexible wire through it OR a turkey baster with some warm water.
The biggest problem is figuring out how to get a seal onto the tube so you can clear it
Once clear it is a good idea to flush it out with a 10% bleach solution.
This will kill any crud growing in the tube and hopefully also let you flush it out.
Just be sure that you do not overflow the drip tray.
Also wear old clothes, at least I have to as I always seem to get some of the bleach on my clothes.
__________________
  #3 (permalink)
Old 02-02-2011, 05:00 PM
Junior Member
LGman1966 is on a distinguished road
Default
If OK
Thanks denman! Your suggestions really helped. I had this issue, and was able to get everything de-iced and working once again. The best part is, no more ice on the bottom! I'm not sure if this is exactly what you said to do, but I removed the back panel (could see the ice trail coming from it) and there were coils with a pan and a hole down the middle. The whole pan was filled with ice. I popped that out in big peices then got rid of as much water as possible. Then after pouring some boiling water in the tray, I heard it drain once more. Success!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
freezer on my side by side is collecting ice in the bottom of the feezer rgosch Refrigerator & Freezer Repair 2 06-25-2012 10:38 AM
water collecting in bottom of refrigerator under the vegetable bins regans2 Refrigerator & Freezer Repair 6 07-27-2011 06:04 PM
freezer on my side by side is collecting ice in the bottom of the feezer rgosch Refrigerator & Freezer Repair 0 11-05-2009 06:41 AM
Water collecting on bottom of fridge kakoopman Refrigerator & Freezer Repair 1 08-29-2009 10:45 PM
water collecting in the bottom of fridge tdbiwmw Refrigerator & Freezer Repair 5 11-13-2008 12:19 PM
