It is only dispensing crushed ice. Visually, everythings seems fine. I can select 'Cubed', 'Crushed' and 'water' and the appropriate light displays. Last night I took the entire icebox out, inspected it and left it out overnight. While out I didnt see anything out of the ordinary although I'm not sure what everything is and how it works. Again, with the icebox out, I selected both crushed and cubed and the motor turns, all seems well.
It sat out all night, it dried and was cleaned and re-inserted. Same problem, still no cubed ice.
Any ideas? Thanks, Chris
