| » Hotwired Icemaker Fill Valve Works OK |
Model Number: HSS25GFPAWW Brand: Hotpoint Age: 1 - 5 years
More troubleshooting info for any Expert that can help...
My problem was an icemaker that doesn't fill. I hotwired the valve and the icemaker fills fine. So is the problem the control board? Or the icemaker signaling the control board? Any ideas how to further isolate the problem? I checked the connections to the control board and all seemed OK. It's an electronic icemaker w/ green LED. LED is on solid. I have reset icemaker several times w/ no change. Any ideas will be appreciated. Thanks, CC Related Models |
Turn icemaker of for 30 seconds, turn back on and push the paddle back 3 times within 5 seconds, the icemaker should cycle takes about 3 minutes, let me know if it fills with water
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!! Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up. |
Quote:
CC |
I would have to say, replace your icemaker. If you put 120volts to the solenoid and you get water to the icemaker, then you have an icemaker that is not sending that signal to fill. Your main board is fine, your icemaker is not.
__________________
currently 8 years experiance as a GE tech tells me your board is ok. I have never seen an icemaker issue caused by a bad board. I like my odds on this one.
__________________
Get me your serial# so I can check something for you
__________________
Chip, I looked at your model, and your board is under a rework by GE, you can call GE to come and put a new board in for free.
__________________
| Display Modes | |
| Icemaker does not fill | draring | Refrigerator & Freezer Repair | 0 | 02-09-2008 05:38 PM |
| How can I test a fill valve? | geoghegan | Dishwasher Repair | 1 | 01-31-2008 08:41 PM |
| IceMaker won't fill | Snowman | Refrigerator & Freezer Repair | 1 | 12-02-2007 11:57 PM |
| No Power to fill valve | dpk1000 | Dishwasher Repair | 2 | 09-13-2007 08:57 PM |
| Ice maker still leaking - Just replaced fill valve | Adam80 | Refrigerator & Freezer Repair | 1 | 09-12-2007 08:09 PM |
