rco224
#1 Posted : Tuesday, June 17, 2008 11:35:32 AM(UTC)
rco224
I need help with this. The ice maker is getting plenty of water and working normally. The water side is not putting water out. The switch is engaging when the lever is depressed but I'm not getting any water. Please advise. Thanks:confused:
abadfish66
#2 Posted : Tuesday, June 17, 2008 11:47:24 AM(UTC)
abadfish66
Pull your grille (kick plate) off at the bottom, and locate the waterline coming from the bottom hinge of the freezer door, there is a union connector there, disconnect one side of the waterline, now with the freezer door closed, push for water like your getting a glass of water. If water comes out of the hose you disconnected, the line is frozen in the door, if no water comes out of the hose problem is elsewhere....Post your results
Ice And Water Dispensor Switch Sticks (Refrigerator & Freezer Repair)
by Craig Rich 1/2/2018 8:10:07 AM(UTC)
Refrigerator Water Dispensor not working (Refrigerator & Freezer Repair)
by aperkins187 2/6/2013 6:18:03 AM(UTC)
water dispensor pressed ice maker overflows (Refrigerator & Freezer Repair)
by 3dshooter1 7/29/2012 6:14:10 PM(UTC)
by Cali12b10 2/27/2012 11:43:16 AM(UTC)
Water Dispensor drips/Waterline at icemaker freezes up. (Refrigerator & Freezer Repair)
by Bella James 12/2/2011 10:19:33 AM(UTC)
ice & water dispensor problem (Refrigerator & Freezer Repair)
by W9RUK 7/19/2011 11:41:16 AM(UTC)
Water Dispensor (Refrigerator & Freezer Repair)
by tlattimore1 5/12/2011 12:01:31 PM(UTC)
Water dispensor not working on GE Profile (Refrigerator & Freezer Repair)
by millertcb 3/21/2011 12:24:43 PM(UTC)
water dispensor not working (Refrigerator & Freezer Repair)
by dan donaldson9 9/24/2010 11:01:18 AM(UTC)
by expetrush 6/21/2010 10:15:48 AM(UTC)
GE water dispensor leaking (Refrigerator & Freezer Repair)
by benhale 5/16/2010 6:00:53 PM(UTC)
Water Dispensor leaking (Refrigerator & Freezer Repair)
by jerla 3/9/2010 4:56:50 PM(UTC)
Water Dispensor Won't Turn Off (Refrigerator & Freezer Repair)
by mwsievers 2/22/2010 1:20:14 PM(UTC)
Water dispensor (Refrigerator & Freezer Repair)
by JC1 7/1/2009 2:47:07 PM(UTC)
automatic ice and water dispensor not working (Refrigerator & Freezer Repair)
by Colin Twedt 6/20/2009 8:08:53 PM(UTC)
