Discuss
Water in and under fridge
 in
Refrigerator & Freezer Repair
I don't have the model, will get it this evening if it's needed. This is the Whirlpool without
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Water in and under fridge
  #1 (permalink)
Old 06-17-2008, 10:20 AM
Kirk Kirk is offline
Junior Member
Kirk is on a distinguished road
Default Water in and under fridge
Brand: Whirlpool   Age: 1 - 5 years
I don't have the model, will get it this evening if it's needed. This is the Whirlpool without handles, there is a slot on top of the fridge door, bottom of the freezer door.
Here is the problem: I hope there is enough info here as I know little about the workings of this refiridgerator.
I noticed water on one of the shelves, wiped it up thought it was a spill. Later I noticed more water and then heard water dripping when the icemaker cycled, then I noticed that water is coming from holes at the top of the fridge area when the icemaker cycled. The drain tray underneath has filled and overflowed.
It appears that when the icemaker fills, water runs directly into the fridge area. Some ice is still being made, I didn't leave it running to determine if there is less ice or not.
Because I don't know for sure what is happening here I've turned off the icemaker with the arm and turned off the water valve to the icemaker.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-17-2008, 05:48 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Kirk,
The first thing I would check are all water lines inside and outside. Check the water feeding tube into the ice maker - it could be dislodged. The model number is important for more accurate advise.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Water in Fridge Shimon Refrigerator & Freezer Repair 1 06-12-2008 10:15 PM
No water or ice from fridge ediconex99 Refrigerator & Freezer Repair 1 05-09-2008 07:27 AM
water in bottom of fridge mtrimboli Refrigerator & Freezer Repair 3 03-02-2008 03:45 PM
Water In Fridge GIFFORD95 Refrigerator & Freezer Repair 1 01-14-2008 06:20 PM
Kenmore fridge - water drips into fridge njblue55 Refrigerator & Freezer Repair 3 08-07-2007 08:50 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
