My Whirlpool side by side refridgerator model #ED5PHEXR000 is'nt cooling like it should.The freezer seems fine,but the fridge is not as cold as it should be.Theres a very light flow of air coming from the vent in the top right hand corner of the fridge.Im not sure of how strong this flow should be.If i had to geuss id say this is where the problem is located.Any help would be appreciated.Thanks.
Look at the freezer side of this vent. See if it is restricted or blocked by ice, food; or if the damper is partially closed.
