Discuss
Ice Maker Fire Hazard
 in
Refrigerator & Freezer Repair
I have a 2002 Maytag SXS refrigerator. Two years ago one of the electrical boards for the icemaker burnt and
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Ice Maker Fire Hazard
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 09-04-2007, 12:37 PM
rburgess rburgess is offline
Junior Member
rburgess is on a distinguished road
Default Ice Maker Fire Hazard
Model Number: MSD2354DRW   Brand: Maytag   Age: 1 - 5 years
I have a 2002 Maytag SXS refrigerator. Two years ago one of the electrical boards for the icemaker burnt and melted a few of the parts. We replaced the board and parts and now in August 2007 both boards burnt and melted the casing and several other parts. Both times we have not been home and are now afraid it poses a fire hazard. Is this common with this make or has anyone else had similar problems with this make and model? We are now debating purchasing a new fridge?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-04-2007, 03:45 PM
ApplianceJunk's Avatar
ApplianceJunk ApplianceJunk is offline
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
Are you taking about the board in the freezer door?
__________________
You can Repair your Appliance & we can help with our Appliance Repair Forum and Appliance Repair Blog.
  #3 (permalink)
Old 09-04-2007, 05:16 PM
Junior Member
Default Ice maker Fire hazard
yes there are 2 boards in the freezer door after you take the panel off the ice maker.
rburgess
  #4 (permalink)
Old 10-08-2007, 12:57 PM
AZDIY AZDIY is offline
Junior Member
AZDIY is on a distinguished road
Default There is definitely a problem with Maytag control boards
When I purchased my home 2 years ago it came with a Maytag MSD2555... and the reason the previous owners left it was because the ice maker/fountain did not work. I tore it apart and found the blackened control board and melted plastic parts in the housing. I ordered all the necessary parts from appliancepartspros.com (who are a great company to deal with) and made the repairs.
All aspects of the ice/water functioned great for 1 year and nearly to the day the circuit board had another meltdown. I was asleep at the time and heard loud popping from the kitchen. I ran in to see smoke pouring from the front of the ice maker controls and a very foul smell of burnt electronics. I unplugged the fridge and tore down the assembly and it was the exact same mode of failure and melted plastic. I decided not to repair again due to the potential fire hazard. I just left all of the wire harnesses unplugged.
I think this is a definite hazard and should be a major recall for Maytag, but since I am not a licensed Maytag repair man I doubt they would entertain my story as anything but user error.
This weekend the fridge totally died and I will replace rather than even attempt a repair. The problem is that the opening is sized for a similar Maytag, but unless I can comfirm a redesign of this circuitry it is tough to by a new Maytag. I have been looking through the part numbers for these control boards trying to discern at what point and which models have an updated circuit. Any help from those with more experience would be appreciated.
  #5 (permalink)
Old 07-14-2008, 03:55 PM
j3mlundy j3mlundy is offline
Junior Member
j3mlundy is on a distinguished road
Default
I have a Jenn-air SXS with what appears to be a similar problem. Jenn-air and Maytag share parts. Recently the unit stopped responding to the touchpad buttons on the front. The crushed ice led was stuck on and the illumination light was on. By the next day all the lights had gone off. I disassembled the unit and found that the control pc board had a burned area, the ice door solenoid plunger was frozen, and the plastic around the solenoid was deformed by heat. What I believe happened is that the solenoid was stuck on as well as the lights when the controls stuck. The solenloid overheated and finally some of the circuits driving the solenoid fried and started a small fire on the pc board. I replaced everything that appeared to be damaged (control pc board, solenoid [with ice door and control arm which came as a package], main plastic housing [which held the solenoid]). The main things I did not replace were the dispenser micro switch and the touchpad pc board. The unit ran fine including dispensing ice and water for 5 minutes and then the controls stuck again. By stuck I mean would not respond to buttons pushes or dispense request any more, the crushed ice led was stuck on and the illumination was on. At this time I notice that the ice door opened and stuck in the open position (ie the solenoid was on). So I shut the unit down immediately and took it apart again. This time none of the parts appeared to be damage, but when I reassembled it the controls are still stuck. So I am not sure what to do next. Has the control board failed again or is there something wrong with the dispensing micro switch or the touchpad pc board. The touchpad pc board seems to be very simple. Mostly touch switches, leds, and some resisters. I metered the micro switch and it appears to be working fine. Anyone have any ideas? Did anyone get this problem understood and fixed before? My Jennair was bought around 2002 as well, and this problem has just happened.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer does not fire Captain Carquest Dryer Repair 1 08-20-2007 09:55 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
