Discuss
KitchenAid Suberba - Walter Filter Leaks
 in
Refrigerator & Freezer Repair
When water is connected and water filter cartridge is in the housing, the water leaks out (really, it gushes out)
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » KitchenAid Suberba - Walter Filter Leaks
  #1 (permalink)
Old 06-13-2008, 06:20 AM
mgwylie mgwylie is offline
Junior Member
mgwylie is on a distinguished road
Default KitchenAid Suberba - Walter Filter Leaks
Model Number: Superba   Brand: Kitchen Aid   Age: 1 - 5 years
When water is connected and water filter cartridge is in the housing, the water leaks out (really, it gushes out) under the filter housing. If I take out the filter cartridge, it does not leak. Any idea what the problem is? This is a Kitchen Aid Superba fridge, probably about 2 years old. I cannot find a model number sticker on it.
Thanks,
Matthew
Related Models
Whirlpool SVC80W
Whirlpool SVC80W1
Whirlpool SVC80W2
Whirlpool SVC80W3
Jenn-Air SVD48600B Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600BC Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600P Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600PC Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600PF Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600PG Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600PK Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600PR Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600PT Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600PU Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600W Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600WC Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310S Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310S-C Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SD Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SF Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SG Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SK Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SR Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SU Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVE47100B Range - S/c S/i Ddraft Ele
Jenn-Air SVE47100BC Range - S/c S/i Ddraft Ele
Jenn-Air SVE47100W Range - S/c S/i Ddraft Ele
Jenn-Air SVE47100WC Range - S/c S/i Ddraft Ele
Jenn-Air SVE47500B Range - S/c S/i Ddraft Ele
Jenn-Air SVE47500W Range - S/c S/i Ddraft Ele
Jenn-Air SVE47600B Range - S/c S/i Ddraft Ele
Jenn-Air SVE47600BC Range - S/c S/i Ddraft Ele
Jenn-Air SVE47600W Range - S/c S/i Ddraft Ele
Jenn-Air SVE47600WC Range - S/c S/i Ddraft Ele
Jenn-Air SVE87600B Range - S/c S/i Ddraft Ele
Jenn-Air SVE87600W Range - S/c S/i Ddraft Ele
Whirlpool SVF100W0
Whirlpool SVF100W1
Whirlpool SVF12FRHW00
Whirlpool SVF15NRHW00
Whirlpool SVF15NRHW01
Whirlpool SVF15NRHW02
Whirlpool SVF15NRJW00
Whirlpool SVF20NRKQ00
Whirlpool SVF60W0
Whirlpool SVF60W1
Whirlpool SVF70W0
Whirlpool SVF70W1
Whirlpool SVF75W0
Whirlpool SVF75W1
Whirlpool SVF75W2
Whirlpool SVF80W0
Whirlpool SVF80W1
Whirlpool SVF90W0
Whirlpool SVF90W1
Whirlpool SVP100W0
Whirlpool SVP50W0
Whirlpool SVP60W0
Whirlpool SVP60W1
Whirlpool SVP70W0
Whirlpool SVP75W0
Whirlpool SVP80W0
Whirlpool SVP90W0
Whirlpool SVU100W0
Whirlpool SVU100W1
Whirlpool SVU100W2
Whirlpool SVU60W0
Whirlpool SVU60W1
Whirlpool SVU60W2
Whirlpool SVU70W0
Whirlpool SVU70W1
Whirlpool SVU70W2
Whirlpool SVU80W0
Whirlpool SVU80W1
Whirlpool SVU80W2
Whirlpool SVU90W0
Whirlpool SVU90W1
Whirlpool SVU90W2
Amana SW22H Ref - SXS/I&W
Amana SW22MBG Ref - SXS/I&W
Amana SW22MBL Ref - SXS/I&W
Amana SW22MBW Ref - SXS/I&W
Amana SW25H Ref - SXS/I&W
Amana SWDT22H Ref - SXS/I&W
Amana SWDT25H Ref - SXS/I&W
Whirlpool SWF100W0
Whirlpool SWF100W2
Whirlpool SWF60W0
Whirlpool SWF60W2
Whirlpool SWF70W0
Whirlpool SWF70W2
Whirlpool SWF80W0
Whirlpool SWF80W2
Whirlpool SWF80W8
Whirlpool SWF80W9
Whirlpool SWF90W0
Whirlpool SWF90W1
Whirlpool SWF90W2
Amana SWP25H Ref - SXS/I&W
Whirlpool SWP70W0
Whirlpool SWP80W0
Whirlpool SWP90W0
Amana SWPD25H Ref - SXS/I&W
White Westinghouse SWS1233CQ0 White Westinghouse/washer
White Westinghouse SWS1233CQ1 White Westinghouse/washer
White Westinghouse SWS1233CS0 White Westinghouse/washer
White Westinghouse SWS1233CS1 White Westinghouse/washer
White Westinghouse SWS1339CC1 White Westinghouse/washer
White Westinghouse SWS1339CC2 White Westinghouse/washer
White Westinghouse SWS1549AQ0 Washer - W.westinghouse
White Westinghouse SWS1549AQ1 Washer - West/grupo Famsa
White Westinghouse SWS1549AQ2 White Westinghouse/washer
White Westinghouse SWS1549AS0 Washer - W.westinghouse
White Westinghouse SWS1549AS1 Washer - West/grupo Famsa
White Westinghouse SWS1549AS2 White Westinghouse/washer
  #2 (permalink)
Old 06-13-2008, 07:02 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
In order to provide most accurate advise we need the complete model number of the refrigerator. The "model number locator" should help you to find it.
__________________
  #3 (permalink)
Old 06-14-2008, 08:26 AM
Junior Member
Default No Model Number
I cannot find the model number. The sticker appears to be missing. I have used your model number locator and also the guidelines on the KitchenAid site. It looks identical to the KSCS22QFWH01, except that that model doesn't seem to have the circular hole for the filter at the bottom (by the toe-kick).
Matthew
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
water filter available? jptlkosborn Refrigerator & Freezer Repair 2 11-26-2007 07:17 PM
Lint Filter problem Dan Pearl Dryer Repair 1 11-08-2007 04:55 PM
Filter indicator light red ag1680 Refrigerator & Freezer Repair 1 08-01-2007 10:28 PM
frig. leaks from filter p1rat Refrigerator & Freezer Repair 0 08-01-2007 09:04 AM
