Discuss
Frigidaire ice maker switch shut off arm won't go down to on
 in
Refrigerator & Freezer Repair
The shut off arm that turns the ice maker on and off when the tray is full will not go
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Frigidaire ice maker switch shut off arm won't go down to on
  #1 (permalink)
Old 04-09-2010, 02:31 AM
Junior Member
lcapelis is on a distinguished road
Default Frigidaire ice maker switch shut off arm won't go down to on
Model Number: FRS23H7CW0   Brand: Frigidaire   Age: 1 - 5 years
The shut off arm that turns the ice maker on and off when the tray is full will not go down to the vertical (on) position. I can easily move it between horizontal (off) and 45 degrees down from horizontal. It was working fine, until I turned it off because it doesn't always shut off when the tray is full . . . now I cannot turn it back on by dropping the arm to vertical. Part number 22 on the blow up . . Ice is below touching the arm to hold it up, and when I wiggle the arm between horizontal and the 45 degree point where it stops, it feels like it is going into a bind. Parts blow up shows micro switch and possibly a lever arm connected to it. Could it be frozen with ice in there?? Can I unplug this ice maker without causing damage to the main board electronics for the fridge, and still leave the fridge plugged in? Thanks in advance for any advice. I have attached parts blow up if it helps. Ice maker is on page 18 parts list for ice maker is page 19
Related Models
Frigidaire FRS23H7CW0 Frigidaire/refrigerator
Frigidaire FRS23H7CW1 Frigidaire/refrigerator
Frigidaire FRS23H7CW2 Frigidaire/refrigerator
Frigidaire FRS23HF5AB1 Frigidaire/refrigerator
Frigidaire FRS23HF5AB2 Frigidaire/refrigerator
Frigidaire FRS23HF5AB3 Frigidaire/refrigerator
Frigidaire FRS23HF5AB4 Frigidaire/refrigerator
Frigidaire FRS23HF5AB5 Frigidaire/refrigerator
Frigidaire FRS23HF5AQ1 Frigidaire/refrigerator
Frigidaire FRS23HF5AQ2 Frigidaire/refrigerator
Frigidaire FRS23HF5AQ3 Frigidaire/refrigerator
Frigidaire FRS23HF5AQ4 Frigidaire/refrigerator
Frigidaire FRS23HF5AQ5 Frigidaire/refrigerator
Frigidaire FRS23HF5AW1 Frigidaire/refrigerator
Frigidaire FRS23HF5AW2 Frigidaire/refrigerator
Frigidaire FRS23HF5AW3 Frigidaire/refrigerator
Frigidaire FRS23HF5AW4 Frigidaire/refrigerator
Frigidaire FRS23HF5AW5 Frigidaire/refrigerator
Frigidaire FRS23KF5CB0 Frigidaire/refrigerator
Frigidaire FRS23KF5CB2 Frigidaire/refrigerator
Frigidaire FRS23KF5CB3 Frigidaire/refrigerator
Frigidaire FRS23KF5CB5 Frigidaire/refrigerator
Frigidaire FRS23KF5CQ0 Frigidaire/refrigerator
Frigidaire FRS23KF5CQ2 Frigidaire/refrigerator
Frigidaire FRS23KF5CQ3 Frigidaire/refrigerator
Frigidaire FRS23KF5CQ5 Frigidaire/refrigerator
Frigidaire FRS23KF5CS0 Frigidaire/refrigerator
Frigidaire FRS23KF5CS2 Frigidaire/refrigerator
Frigidaire FRS23KF5CW0 Frigidaire/refrigerator
Frigidaire FRS23KF5CW2 Frigidaire/refrigerator
Frigidaire FRS23KF5CW3 Frigidaire/refrigerator
Frigidaire FRS23KF5CW5 Frigidaire/refrigerator
Frigidaire FRS23KF5DB0 Frigidaire/refrigerator
Frigidaire FRS23KF5DB1 Frigidaire/refrigerator
Frigidaire FRS23KF5DB2 Frigidaire/refrigerator
Frigidaire FRS23KF5DB4 Frigidaire/refrigerator
Frigidaire FRS23KF5DB7 Frigidaire/refrigerator
Frigidaire FRS23KF5DQ0 Frigidaire/refrigerator
Frigidaire FRS23KF5DQ1 Frigidaire/refrigerator
Frigidaire FRS23KF5DQ2 Frigidaire/refrigerator
Frigidaire FRS23KF5DQ4 Frigidaire/refrigerator
Frigidaire FRS23KF5DQ7 Frigidaire/refrigerator
Frigidaire FRS23KF5DS0 Frigidaire/refrigerator
Frigidaire FRS23KF5DS1 Frigidaire/refrigerator
Frigidaire FRS23KF5DS2 Frigidaire/refrigerator
Frigidaire FRS23KF5DS4 Frigidaire/refrigerator
Frigidaire FRS23KF5DW0 Frigidaire/refrigerator
Frigidaire FRS23KF5DW1 Frigidaire/refrigerator
Frigidaire FRS23KF5DW2 Frigidaire/refrigerator
Frigidaire FRS23KF5DW3 Frigidaire/refrigerator
Frigidaire FRS23KF5DW4 Frigidaire/refrigerator
Frigidaire FRS23KF5DW7 Frigidaire/refrigerator
Frigidaire FRS23KF6CB0 Frigidaire/refrigerator
Frigidaire FRS23KF6CB1 Frigidaire/refrigerator
Frigidaire FRS23KF6CB2 Frigidaire/refrigerator
Frigidaire FRS23KF6CQ0 Frigidaire/refrigerator
Frigidaire FRS23KF6CQ1 Frigidaire/refrigerator
Frigidaire FRS23KF6CQ2 Frigidaire/refrigerator
Frigidaire FRS23KF6CW0 Frigidaire/refrigerator
Frigidaire FRS23KF6CW1 Frigidaire/refrigerator
Frigidaire FRS23KF6CW2 Frigidaire/refrigerator
Frigidaire FRS23KF6DB0 Frigidaire/refrigerator
Frigidaire FRS23KF6DB1 Frigidaire/refrigerator
Frigidaire FRS23KF6DB2 Frigidaire/refrigerator
Frigidaire FRS23KF6DB5 Frigidaire/refrigerator
Frigidaire FRS23KF6DB8 Frigidaire/refrigerator
Frigidaire FRS23KF6DQ0 Frigidaire/refrigerator
Frigidaire FRS23KF6DQ1 Frigidaire/refrigerator
Frigidaire FRS23KF6DQ2 Frigidaire/refrigerator
Frigidaire FRS23KF6DQ8 Frigidaire/refrigerator
Frigidaire FRS23KF6DW0 Frigidaire/refrigerator
Frigidaire FRS23KF6DW1 Frigidaire/refrigerator
Frigidaire FRS23KF6DW2 Frigidaire/refrigerator
Frigidaire FRS23KF6DW4 Frigidaire/refrigerator
Frigidaire FRS23KF6DW8 Frigidaire/refrigerator
Frigidaire FRS23KF6EB0 Frigidaire/refrigerator
Frigidaire FRS23KF6EB1 Frigidaire/refrigerator
Frigidaire FRS23KF6EB2 Frigidaire/refrigerator
Frigidaire FRS23KF6EB3 Frigidaire/refrigerator
Frigidaire FRS23KF6EB4 REFRIGERATOR
Frigidaire FRS23KF6EB5 Frigidaire/refrigerator
Frigidaire FRS23KF6EB6 REFRIGERATOR
Frigidaire FRS23KF6EB7 REFRIGERATOR
Frigidaire FRS23KF6EB8 REFRIGERATOR
Frigidaire FRS23KF6EBA REFRIGERATOR
Frigidaire FRS23KF6EBB REFRIGERATOR
Frigidaire FRS23KF6EBC REFRIGERATOR
Frigidaire FRS23KF6EBD REFRIGERATOR
Frigidaire FRS23KF6EBE REFRIGERATOR
Frigidaire FRS23KF6EM0 Frigidaire/refrigerator
Frigidaire FRS23KF6EM1 Frigidaire/refrigerator
Frigidaire FRS23KF6EM2 Frigidaire/refrigerator
Frigidaire FRS23KF6EM3 Frigidaire/refrigerator
Frigidaire FRS23KF6EM4 REFRIGERATOR
Frigidaire FRS23KF6EM5 Frigidaire/refrigerator
Frigidaire FRS23KF6EM6 REFRIGERATOR
Frigidaire FRS23KF6EM7 REFRIGERATOR
Frigidaire FRS23KF6EM8 REFRIGERATOR
Frigidaire FRS23KF6EMA REFRIGERATOR
Frigidaire FRS23KF6EMB REFRIGERATOR
Frigidaire FRS23KF6EMC REFRIGERATOR
Frigidaire FRS23KF6EMD REFRIGERATOR
Frigidaire FRS23KF6EME REFRIGERATOR
Frigidaire FRS23KF6EW0 Frigidaire/refrigerator
Frigidaire FRS23KF6EW1 Frigidaire/refrigerator
Frigidaire FRS23KF6EW2 Frigidaire/refrigerator
Frigidaire FRS23KF6EW3 Frigidaire/refrigerator
Frigidaire FRS23KF6EW4 Frigidaire/refrigerator
Frigidaire FRS23KF6EW5 Frigidaire/refrigerator
Frigidaire FRS23KF6EW6 REFRIGERATOR
Frigidaire FRS23KF6EW7 REFRIGERATOR
Frigidaire FRS23KF6EW8 REFRIGERATOR
Frigidaire FRS23KF6EW9 REFRIGERATOR
Frigidaire FRS23KF6EWA REFRIGERATOR
Frigidaire FRS23KF6EWB REFRIGERATOR
Frigidaire FRS23KF6EWC REFRIGERATOR
Frigidaire FRS23KF6EWD REFRIGERATOR
Frigidaire FRS23KF6EWE REFRIGERATOR
Frigidaire FRS23KF7AB0 Frigidaire/refrigerator
Frigidaire FRS23KF7AB1 Frigidaire/refrigerator
  #2 (permalink)
Old 04-09-2010, 09:01 AM
Expert
APP Volunteer
FridgeDoctor is on a distinguished road
Default
you can remove the ice maker without any fear of damaging any electric board. The ice maker is held on by 2-3 screws, and has a simple plug. If you decide you can live without the ice maker, your refrigerator will not be affected. If you want to replace your faulty ice maker, its just as simple to put the new one in. There will not be any ice jamming anything in the ice maker, you have a problem with the ice maker model. Do not attempt to replace just your module, if done incorrectly, the ice maker can stop in the point of the cycle it calls for water, flooding your freezer.
__________________
Refrigerator Repair Service to Chicago Suburbs
  #3 (permalink)
Old 04-11-2010, 05:49 PM
Junior Member
Default
Quoting you: "Do not attempt to replace just your module, if done incorrectly, the ice maker can stop in the point of the cycle it calls for water, flooding your freezer".
Many thanks for the reply . . I am not entirely clear on the concept, are you saying this particular ice maker model has issues, and is prone to stopping in the middle of the cycle, or are you saying I am likely to butter up the installation of just the module, and thereby cause the thing to stop in the middle of the cycle, creating a car wash in a freezer syndrome, or both??
  #4 (permalink)
Old 04-11-2010, 05:53 PM
Junior Member
Default
Nice website by the way, wish I lived closer to Chi than Oregon . . .
  #5 (permalink)
Old 04-11-2010, 09:00 PM
Expert
APP Volunteer
Default
your model does not have any particular issues, but I was saying that if you attempt to replace the ice maker module, which is the main circuit board, motor etc., if you dont do it right, or butter up the installation as you say, it wont work right.
If you replace the entire ice maker, its the least amount of hassle, the least of amount of worry. Just make sure the one you put in has everything the same as the old one, including your bail arm, fill cups, and any clips for the fill tube or the electrical harness.
Furthermore, I appreciate the compliments on my web site, as everything was done by yours truly. I just hope it doesnt look too much like everything was done by yours truly =)
__________________
  #6 (permalink)
Old 04-16-2010, 03:50 PM
Junior Member
Default
Duly noted and many thanks for your efforts . . . and no, your website does NOT look like it was the work of somebody truly . . .
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire Electric stove/cooktop's element will not shut off Morris Oven Repair (including Ranges and Cooktops) 23 05-18-2014 05:03 AM
Frigidaire Stove - broiler wont shut off Peg529 Oven Repair (including Ranges and Cooktops) 3 02-15-2010 04:34 PM
Frigidaire gas oven won't shut off repairs101 Oven Repair (including Ranges and Cooktops) 0 08-13-2009 03:48 PM
Frigidaire Electric cooktop will not shut off Bluzman23 Oven Repair (including Ranges and Cooktops) 1 12-08-2008 03:38 PM
Ice maker will not shut off sundownsec Refrigerator & Freezer Repair 0 04-17-2008 04:24 PM
