Discuss
High Temperature in Upright Freezer
 in
Refrigerator & Freezer Repair
Our Kenmore Upright Frostfree freezer has been working fine for about 8 years. Although the freezer still runs, it only
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » High Temperature in Upright Freezer
  #1 (permalink)
Old 09-04-2007, 11:06 AM
timb timb is offline
Junior Member
timb is on a distinguished road
Default High Temperature in Upright Freezer
Model Number: 253.9280810   Brand: Kenmore   Age: 5 - 10 years
Our Kenmore Upright Frostfree freezer has been working fine for about 8 years. Although the freezer still runs, it only cools to 30-40 degrees. This problem appears to have occurred overnight. The freezer will hold its temperture, just at the higher level. The temperture does swing based on adjustment of the thermostat, with the coldest setting bringing the freezer down to 30 degrees and the warmest setting up to 40 degrees. I have also manually defrosted the unit, but it did not have any effect. What is the likelihood that this can be repaired ecomoically or is there a problem with the sealed system.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
LED clock/temperature light fading an petvetacc Oven Repair (including Ranges and Cooktops) 2 10-24-2007 05:29 PM
Gibson Upright Freezer making loud buzzing noise..... kakizie Refrigerator & Freezer Repair 0 08-02-2007 04:42 PM
Dryer stops before loads are dry,esp on High setting azhorn Dryer Repair 2 08-02-2007 04:05 PM
Frig Temperature control problem vrocrider Refrigerator & Freezer Repair 2 07-29-2007 11:02 AM
loose seal used upright freezer tcarlson762 Refrigerator & Freezer Repair 1 07-25-2007 12:02 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
