Discuss
ice maker or ref problem
 in
Refrigerator & Freezer Repair
I have a maytag ref. the ice maker in it does not work. i bought the ref. used. I have
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » ice maker or ref problem
  #1 (permalink)
Old 04-07-2010, 12:58 PM
Junior Member
BANASZAK is on a distinguished road
Default ice maker or ref problem
Model Number: mff2557hew   Brand: Maytag   Age: 1 - 5 years
I have a maytag ref. the ice maker in it does not work. i bought the ref. used. I have checked the line voltage at the connector for the ice maker and it is not present. I was woundering if there is some rest button for the ice maker. I am not sure if the 115 volt is present at the connector all the time any help would be greatful. i do not want to buy a new ice maker if it is a problem with the ref. Thanks Magician 59 there is an inline fuse to the ice maker. This fuse is on the ice maker connector. Idid check the fuse for conninuty it was good. With this connector disconected I still do not have 115 volts at connector on the ref. did not see any reset on the ref. have wiring diagram but no info on if voltage should be at connector all the time.
Ads By Google
Related Models
Maytag MFF2557HEW Ref - Bottom Mounts
Maytag MFF2557KES Ref - Bottom Mounts
Maytag MFF2558KEB Ref - Bottom Mounts
Maytag MFF2558KES Ref - Bottom Mounts
Maytag MFF2558KEW Ref - Bottom Mounts
Frigidaire MFF312BFWB Frg(v1) / Electric Range
Frigidaire MFF312BFWC Frg(v2) / Electric Range
Frigidaire MFF312BFWE Frg(v3) / Electric Range
Frigidaire MFF318BGDA Wwh(v1) / Electric Range
Frigidaire MFF318BGWA Wwh(v2) / Electric Range
Frigidaire MFF351BCWC Frg(v1) / Electric Range
Frigidaire MFF351BCWD Frg(v2) / Electric Range
Frigidaire MFF351BCWE Frg(v3) / Electric Range
Maytag MFI2067AEB Ref - Bottom Mounts
Maytag MFI2067AEQ Ref - Bottom Mounts
Maytag MFI2067AES Ref - Bottom Mounts
Maytag MFI2067AEW Ref - Bottom Mounts
Maytag MFI2266AEB10 Refrigerator
Maytag MFI2266AEQ10 Refrigerator
Maytag MFI2266AES10 Refrigerator
Maytag MFI2266AEU10 Refrigerator
Maytag MFI2266AEW10 Refrigerator
Maytag MFI2568AEB Ref - Bottom Mounts
Maytag MFI2568AEB12 Refrigerator
Maytag MFI2568AEQ Ref - Bottom Mounts
Maytag MFI2568AEQ12 Refrigerator
Maytag MFI2568AES Frigidaire/refrigerator
Maytag MFI2568AES12 Refrigerator
Maytag MFI2568AEW Ref - Bottom Mounts
Maytag MFI2568AEW12 Refrigerator
Maytag MFR18MCAAS Washer - Top Loading
Maytag MFR18MCAVS Washer - Top Loading
Maytag MFR18PCAAS Washer - Top Loading
Maytag MFR18PCAVS Washer - Top Loading
Maytag MFR18PDAAS Washer - Horizontal Axis
Maytag MFR18PDAVS Washer - Horizontal Axis
Maytag MFR18PDCWS Washer - Horizontal Axis
Maytag MFR25MCATS Washer - Horizontal Axis
Maytag MFR25MCAVS Washer - Horizontal Axis
Maytag MFR25PCATS Washer - Horizontal Axis
Maytag MFR25PCAVS Washer - Horizontal Axis
Maytag MFR25PDATS Washer - Horizontal Axis
Maytag MFR25PDAVS Washer - Horizontal Axis
Maytag MFR25PDCWS Washer - Horizontal Axis
Maytag MFR30PDCTS 29" Gas Dryer
Maytag MFR30PNCTS Washer - Horizontal Axis
Maytag MFR35MCATS Washer - Horizontal Axis
Maytag MFR35MCAVS Washer - Horizontal Axis
Maytag MFR35MNATS Washer - Top Loading
Maytag MFR35MNAVS Washer - Top Loading
Maytag MFR35PCATS Washer - Horizontal Axis
Maytag MFR35PCAVS Washer - Horizontal Axis
Maytag MFR35PDATS Washer - Horizontal Axis
Maytag MFR35PDAVS Washer - Horizontal Axis
Maytag MFR35PNAVS Washer - Horizontal Axis
Maytag MFR35PNBVS Washer - Top Loading
Maytag MFR40PDCTS Washer - Horizontal Axis
Maytag MFR40PNCTS Washer - Horizontal Axis
Maytag MFR50MCATS Washer - Top Loading
Maytag MFR50MCAVS Washer - Top Loading
Maytag MFR50MNAVS Washer - Top Loading
Maytag MFR50PCATS Washer - Top Loading
Maytag MFR50PCAVS Washer - Top Loading
Maytag MFR50PDATS Washer - Horizontal Axis
Maytag MFR50PDAVS Washer - Horizontal Axis
Maytag MFR50PDCTS Washer - Horizontal Axis
Maytag MFR50PNAVS Washer - Top Loading
Maytag MFR50PNBVS Washer - Top Loading
Maytag MFR60PDCTS Washer - Horizontal Axis
Maytag MFR60PNCTS Washer - Horizontal Axis
Maytag MFR80PCAVS Washer - Top Loading
Maytag MFR80PDAVS Washer - Top Loading
Maytag MFR80PDCTS Washer - Horizontal Axis
Maytag MFR80PNCTS Washer - Horizontal Axis
Maytag MFS100PAVS Washer - Horizontal Axis
Maytag MFS100PFVS Washer - Horizontal Axis
Maytag MFS125PAVS Washer - Horizontal Axis
Maytag MFS125PFVS Washer - Horizontal Axis
Maytag MFS25PNAVS Washer - Top Loading
Maytag MFS25PNFTS Washer - Horizontal Axis
Maytag MFS35PNAVS Washer - Top Loading
Maytag MFS35PNDVS Washer - Top Loading
Maytag MFS35PNFTS Washer - Horizontal Axis
Maytag MFS50PNAVS Washer - Top Loading
Maytag MFS50PNDVS Washer - Top Loading
Maytag MFS50PNFVS Washer - Horizontal Axis
Maytag MFS75PNAVS Washer - Top Loading
Maytag MFS80PNAVS Washer - Top Loading
Maytag MFS80PNDVS Washer - Top Loading
Maytag MFS80PNFVS Washer - Horizontal Axis
Maytag MFS90PNAVS Washer - Horizontal Axis
Frigidaire MFU05M3AW0 Frg(v1) / Upright Freezer
Frigidaire MFU05M3AW1 Frg(v0) / Upright Freezer
Frigidaire MFU07M3AW0 Frg(v1) / Upright Freezer
Frigidaire MFU07M3AW1 Frg(v0) / Upright Freezer
Frigidaire MFU09M2AW0 Tap(v7) / Upright Freezer
Frigidaire MFU09M2AW1 Tap(v8) / Upright Freezer
Frigidaire MFU09M2BW0 Tap(v4) / Upright Freezer
Frigidaire MFU09M2BW1 Frg(v1) / Upright Freezer
Frigidaire MFU09M2BW2 Frg(v0) / Upright Freezer
Frigidaire MFU09M2BW3 Frg(v0) / Upright Freezer
Frigidaire MFU09M2BW4 Frg(v0) / Freezer
Frigidaire MFU09M2GW0 Frg(v0)
Frigidaire MFU09M2GW2 Frg(v0) / Freezer
Frigidaire MFU09M2GW3 Frg(v0) / Freezer
Frigidaire MFU09M2GW4 Frg(v0) / Freezer
Frigidaire MFU09M2GW5 Frg/freezer
Frigidaire MFU09M2GW6 Frigidaire/freezer
Frigidaire MFU12M0BW0 Tap(v4) / Upright Freezer
Frigidaire MFU12M0BW1 Frg(v1) / Upright Freezer
Frigidaire MFU12M0BW2 Frg(v0) / Upright Freezer
Frigidaire MFU12M0BW3 Frg(v0) / Upright Freezer
Frigidaire MFU12M0BW4 Frg(v0) / Freezer
Frigidaire MFU12M0GW0 Frg(v0)
Uni MFU12M0GW2 Frigidaire/freezer
Frigidaire MFU12M2AW0 Tap(v10) / Upright Freezer
Frigidaire MFU12M2AW1 Tap(v11) / Upright Freezer
Frigidaire MFU12M2AW2 Tap(v12) / Upright Freezer
Frigidaire MFU12M2BW0 Tap(v4) / Upright Freezer
Frigidaire MFU12M2BW1 Frg(v1) / Upright Freezer
  #2 (permalink)
Old 04-07-2010, 02:21 PM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
Here's a wiring diagram. There appears to be an inline fuse (upper right hand corner) associated with the harness connector to the icemaker. I can't tell whether it's on the refrig side, or the icemaker side; but you might check there for continuity (Unplug the machine, first)
http://www.appliancepartspros.com/pa...66&NewWindow=1
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ice Maker Problem Wild Willy Refrigerator & Freezer Repair 0 08-23-2009 07:42 AM
ice maker problem cghessel Refrigerator & Freezer Repair 1 06-03-2009 04:44 PM
Ice Maker problem rrjbwilli Refrigerator & Freezer Repair 1 05-16-2009 03:19 PM
ice maker problem ronnieman Refrigerator & Freezer Repair 0 04-01-2009 04:18 PM
Ice maker problem dlf Refrigerator & Freezer Repair 1 05-15-2008 12:34 PM
