Water is dripping from water dispenser. I can not locate the water valve and how to get to it. Any help is appreciated.
Regards BP :confused:
Groups: Expert
i just looked at the schematic for your model #, its part number 800 on the UNIT parts list. its located in back.
But the water is dripping in the water dispenser area. And part 800 does not seems to have any electrical wires. So how does it control the flow of the water when the dispenser is turned on.
I just need to understand it little better before I purchase the part and do all the work.
I appreciated the response will even more appreciate a reply.
Thanks BP
Groups: Expert
you asked where the water valve is, part 800is the water valve, that is what opens up, and is now failing to close, to let the water flow TO the door dispenser
Thanks parts 800 worked. It also have electric motor connectors. So when the dispenser button is pressed it actually triggers the volve to open in the back.
it worked. thanks again.
Bp
