Just moved to a new place. My Frigidaire Gallery Professional series refrigerator and freezer already broke 4 times. First the condensor burnt out, then the panel. It was repaired only to break down couple of weeks later - perpetually. Seller refuses to replace, but covers the repairs. It shows 70F in fridge and freezer, after compressor is replaced, it works for couple of weeks - then the same story. Ice maker does not work again, it had an electrical spark when I pushed the bottom to make ice, then the panel burns out - no ice, no crush, no water. On the top hinge that holds the door, there is an electrical spark too. Water supply underneath is OK to the ice maker. Is it possessed? Or is it bad repair work? Or is it just a piece of junk? It has never been used before me. Yet it is out of warranty when I called. Please help, I would like to have some food in the house.
sounds like it's haunted! At any rate, I wouldn't throw any more money into it.
