2 Pages12>
BRI129
#1 Posted : Tuesday, June 10, 2008 3:06:30 AM(UTC)
BRI129
Hello All, We Had Notice The Temp Higher Then Normal.move Refrig Out, Fan Not Coming On?? I Can Turn Fan And It Will Spin .we Put A House Fan Behind Refrig Temp Comes Back Down.
Any Help Thank You In Advance
Thanks Brian
abadfish66
#2 Posted : Tuesday, June 10, 2008 7:41:31 AM(UTC)
abadfish66
Can you provide me a serial#.
BRI129
#3 Posted : Wednesday, June 11, 2008 3:10:23 AM(UTC)
BRI129
Hello, Thank You For Your Time.the S/n Is LL041263
Thank You Brian
BRI129
#4 Posted : Wednesday, June 11, 2008 7:15:34 AM(UTC)
BRI129
G/e Refrig S/n Ll041263
abadfish66
#5 Posted : Wednesday, June 11, 2008 7:34:29 AM(UTC)
abadfish66
Let's find out if your fan or board is bad, disconnect the plug from the condenser fan and measure voltage from the red an white wire, you should have about 13volts DC,this is a dc motor so make sure you have your meter set on dc. If you have 13 volts replace the motor, if you don't have 13 volts, replace your board.
BRI129
#6 Posted : Wednesday, June 11, 2008 8:43:51 AM(UTC)
BRI129
Hello Again, I Had Changed The Fan,when I Would Spin It Would Keep Going Slow,so I Thought It Was The Fan. That Board, Is That The
Asm Main Control Board Up By The Water Filter ???
Thanks Again Brian
abadfish66
#7 Posted : Wednesday, June 11, 2008 9:27:55 AM(UTC)
abadfish66
It's on the back wall of the refer should be on the left side, behing a galvenized access panel
BRI129
#8 Posted : Thursday, June 12, 2008 3:17:52 AM(UTC)
BRI129
Hello. There Is 13.79 Vdc Red/white At The Plug Going To Motor.
No Fan
Then I Spin Fan By Hand And It Will Go Slow.looks Slow To Me
This Is A New Motor
What Is The Rpm Of Motor????
Wires At Motor X4 B,w,y,r
Wires At Plug X3 R,p,w
What Is Yellow Wire At Motor ????
Thanks For Your Help
Brian
abadfish66
#9 Posted : Thursday, June 12, 2008 7:16:44 AM(UTC)
abadfish66
Yellow wire is not used on this model, you deffinatly need a new control board, and the good news is your board replacement is covered 100% by GE, There has been a high percentage of these boards failing, and your serial# falls into the board replacement program GE has going on. You wont have to pay anything as long as you call GE for service. When you call in let them no this is not cooling and you should have a tech there same day or next day.
BRI129
#10 Posted : Thursday, June 12, 2008 11:53:00 AM(UTC)
BRI129
Hello, Should I Put The Old Fan Back In,before I Call Them.
Thanks Again For Your Help
2 Pages12>
