Discuss
how do I replace water line in freezer door of an Amana side by side
 in
Refrigerator & Freezer Repair
I didn't get any feedback from my March 20th post so I'm re-posting. If I'm not providing the correct information
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » how do I replace water line in freezer door of an Amana side by side
  #1 (permalink)
Old 03-30-2010, 08:13 PM
Junior Member
clubberlang88 is on a distinguished road
Default how do I replace water line in freezer door of an Amana side by side
Model Number: ARS2667BW   Brand: Amana   Age: 5 - 10 years
I didn't get any feedback from my March 20th post so I'm re-posting. If I'm not providing the correct information needed please let me know and I will do so. Thanks!
Hello.. after diagnosing an issue using this forum I purchased a new water line and would like some pointers on how to install. I have looked at some of the other posts but could not find install procedures for my specific model, or any of the similar models that this waterline fits in. Any help would be much appreciated!!
Thank you in advance
Michael
Ads By Google
Related Models
Amana ARS2667BW Ref - SXS/I&W
Amana ARS266KBB Ref - SXS/I&W
Amana ARS266KBC Ref - SXS/I&W
Amana ARS266KBW Ref - SXS/I&W
Amana ARS266RBB Ref - SXS/I&W
Amana ARS266RBC Ref - SXS/I&W
Amana ARS266RBW Ref - SXS/I&W
Amana ARS266XAW Ref - SXS/I&W
Amana ARS266ZBB  Ref - SXS/I&W
Amana ARS266ZBC  Ref - SXS/I&W
Amana ARS266ZBS  Ref - SXS/I&W
Amana ARS266ZBW  Ref - SXS/I&W
Amana ARS2760BW Ref - SXS/I&W
Amana ARS635 Range - S/c S/i Ddraft Ele
Amana ARS635W Range - S/c S/i Ddraft Ele
Amana ARS636E Range - S/c S/i Ddraft Ele
Amana ARS636WW Range - S/c S/i Ddraft Ele
Amana ARS8265BB  Ref - SXS/I&W
Amana ARS8265BC  Ref - SXS/I&W
Amana ARS8265BS  Ref - SXS/I&W
Amana ARS8265BW  Ref - SXS/I&W
Amana ARS8267BB  Ref - SXS/I&W
Amana ARS8267BC  Ref - SXS/I&W
Amana ARS8267BS  Ref - SXS/I&W
Amana ARS8267BW  Ref - SXS/I&W
Amana ARS9107AS Ref - SXS/I&W
Amana ARS9107AW Ref - SXS/I&W
Amana ARS9167AB Ref - SXS/I&W
Amana ARS9167AC Ref - SXS/I&W
Amana ARS9167AS Ref - SXS/I&W
Amana ARS9167AW Ref - SXS/I&W
Amana ARS9168AB Ref - SXS/I&W
Amana ARS9168AC Ref - SXS/I&W
Amana ARS9168AS Ref - SXS/I&W
Amana ARS9168AW Ref - SXS/I&W
Amana ARS9169AS Ref - SXS/I&W
Amana ARS9265BB  Ref - SXS/I&W
Amana ARS9265BC  Ref - SXS/I&W
Amana ARS9265BW  Ref - SXS/I&W
Amana ARS9266BS  Ref - SXS/I&W
Amana ARS9268BB  Ref - SXS/I&W
Amana ARS9268BC  Ref - SXS/I&W
Amana ARS9268BW  Ref - SXS/I&W
Amana ARS9269BS  Ref - SXS/I&W
Amana ARSE664BB Ref - SXS/I&W
Amana ARSE664BC Ref - SXS/I&W
Amana ARSE664BS Ref - SXS/I&W
Amana ARSE664BW Ref - SXS/I&W
Amana ARSE665BB  Ref - SXS/I&W
Amana ARSE665BC  Ref - SXS/I&W
Amana ARSE665BS  Ref - SXS/I&W
Amana ARSE665BW  Ref - SXS/I&W
Amana ARSE667BB Ref - SXS/I&W
Amana ARSE667BC Ref - SXS/I&W
Amana ARSE667BS Ref - SXS/I&W
Amana ARSE667BW Ref - SXS/I&W
Amana ARSE66MBB Ref - SXS/I&W
Amana ARSE66MBC Ref - SXS/I&W
Amana ARSE66MBW Ref - SXS/I&W
Amana ARSE66ZBB  Ref - SXS/I&W
Amana ARSE66ZBC  Ref - SXS/I&W
Amana ARSE66ZBS  Ref - SXS/I&W
Amana ARSE66ZBW  Ref - SXS/I&W
Amana ARSE67RBB  Ref - SXS/I&W
Amana ARSE67RBC  Ref - SXS/I&W
Amana ARSE67RBS  Ref - SXS/I&W
Amana ARSE67RBW  Ref - SXS/I&W
Amana ART1805BC Ref - Top Mount
Amana ART1805BW Ref - Top Mount
Amana ART2105BB Ref - Top Mount
Amana ART2105BC Ref - Top Mount
Amana ART2105BW Ref - Top Mount
Amana ART2107BB Ref - Top Mount
Amana ART2107BC Ref - Top Mount
Amana ART2107BS Ref - Top Mount
Amana ART2107BW Ref - Top Mount
Amana ART2127AB Ref - Top Mount
Amana ART2127AC Ref - Top Mount
Amana ART2127AS Ref - Top Mount
Amana ART2127AW Ref - Top Mount
Amana ART2129ABR Ref - Top Mount
Amana ART2129ACR Ref - Top Mount
Amana ART2129ASR Ref - Top Mount
Amana ART2129AWR Ref - Top Mount
Amana ART2527AB Ref - Top Mount
Amana ART2527AC Ref - Top Mount
Amana ART2527AW Ref - Top Mount
Amana ART5400L Range - Std Mwave Ele
Amana ART5400W Range - Std Mwave Ele
Amana ART6000L Range - S/c S/i Ddraft Gas
Amana ART6000W Range - S/c S/i Ddraft Gas
Amana ART6001L Range - S/c S/i Ddraft Gas
Amana ART6001W Range - S/c S/i Ddraft Gas
Amana ART6002L Range - S/c S/i Ddraft Gas
Amana ART6002W Range - S/c S/i Ddraft Gas
Amana ART6021C Range - S/c S/i Ddraft Gas
  #2 (permalink)
Old 03-30-2010, 11:18 PM
FridgeDoctor's Avatar
Expert
APP Volunteer
FridgeDoctor is on a distinguished road
Default
May I ask why you believe you need to replace the water line within the confines of the freezer door? This is not a common refrigerator repair. I've had many customers think they have a clog of some sort in the water line, but that really is impossible, unless of course the blockage is ice. But if that is the case, replacing the line wont resolve the issue, as the ice will return until you determine why its building up in the first place.
If you are not getting water out the door dispenser, your most likely problem is either the water valve solenoid is no longer opening to allow water flow past the valve, or there is an electrical issue in the dispenser system itself, or to the connection at the valve.
If you are certain you need to replace the water line, its not an easy job. Before you even attempt anything, you should peel the door gasket/seal back, to look underneath gasket to make sure you can do any repairs. If there are several screws under the gasket, proceed further, if not, stop here, as you will not be able to disassemble the door to get to the water line. your door is glued together, and you will highly regret attempting on your own.
you will have to remove the door entirely from the fridge, including the electrical connection and the water line connection at the bottom. Once the door is removed and laying liner side up on the floor, unscrew and remove all the screws, remove the liner and gasket together, then remove but dont throw out all the fiberglass insulation around the dispenser, You will eventually see the water line fed through the dispenser area. carefully remove the water line from the path around dispenser, then pull it out of the door itself entirely. now take your new water line, and from the bottom of the door, feed it up towards the dispenser, through the same path, making sure that the end of the water line is at the exact same depth in the dispenser, leaving more than enough line at the bottom of the door.
Replace all of the insulation previously removed, its best to put it in the same orientation as it was originally. If you dont pack the insulation as it was, it can cause empty pockets of air inside the door, and its in these pockets that the normal ice condensation build up that occurs inside the door, builds up ice, which can surround a portion of the water line, freezing it, rendering your DIY repair job useless. Reattach the gasket and liner, dont overtighten the screws, as you may crack the door liner, which is not a good thing either. You may have to do some back and forth adjustments, loosening and re tightening screws, to make sure the entire length of all four sides form a tight seal when door is closed. Trim the water line to the correct length, and reattach. make sure you replug in electrical connection.
thats your basic procedure.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
how do I replace water line in freezer door of whirlpool side by side Todd Overton Refrigerator & Freezer Repair 33 02-18-2013 05:19 PM
side by side refrigerator - fridge side freezing food, water coming out of freezer bomb Refrigerator & Freezer Repair 8 08-30-2011 01:58 PM
how do I replace water line in freezer door of an Amana side by side clubberlang88 Refrigerator & Freezer Repair 0 03-21-2010 08:04 PM
Water dispenser line frozen in door-GE side/side JenniferL Refrigerator & Freezer Repair 0 09-27-2009 11:46 AM
ge side by side freezer door no ice/water/light wb7ccj Refrigerator & Freezer Repair 5 07-24-2008 02:30 PM
