Noise coming from back of fridge-no cooling problems though-when rumbling noise started, I hand-stopped fan-went away. Shaft seems loose-is this a common problem-I'm having problems finding the part-it looks like a plastic case, with a clip for power, but the parts I see are smaller metal fans-is there a universal fit?
Thanks!
