Discuss
Noise!
 in
Refrigerator & Freezer Repair
I Have A Whirlpool Single door Refrig . When we Purchased it There were notes stating that it would make
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Noise!
  #1 (permalink)
Old 06-05-2008, 01:14 PM
Junior Member
Sneezy is on a distinguished road
Lightbulb Noise!
Brand: Whirlpool   Age: 1 - 5 years
When we Purchased it There were notes stating that it would make different noises tha what we may be use to.
They were correct but one noise continues to get LOUDER I am assuming it is when the compressor kicks off. It Now Soulds like a mule kick from inside the frig.
Any Answers on what needs to be done to eliminate the noise ?
Ads By Google
  #2 (permalink)
Old 06-05-2008, 01:28 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
Please verify if it is when the compressor turns off. It could be a broken spring inside the compressor. Try and listen where the noise comes from by turning the refer off, and pinpointing the noise.
__________________
  #3 (permalink)
Old 06-06-2008, 02:35 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
If you verify the noise is from the compressor, sometimes you can fix this by removing the compressor mounting clips and tilting the compressor to remove the noise. Worth a try, instead of replacing the compressor.
__________________
  #4 (permalink)
Old 06-09-2008, 02:35 PM
Junior Member
Default
Ok The Noise Sounds like some kind of pop off valve pressure relief
It is very loud and does it 3or 4 times quickly before stopping.
It is comming from the bottom of the frig I said that it is a Whirlpool but it is a Kenmore
8 Years old but the noise has been since new but not nearly as Loud
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
What's that noise? seababble Garbage Disposer Repair 1 04-15-2009 02:10 PM
Noise dlela61 Dryer Repair 1 04-14-2009 04:57 PM
Noise DMILLER Dishwasher Repair 1 04-14-2009 12:51 PM
Noise DMILLER Dishwasher Repair 1 04-14-2009 12:49 PM
Noise lsb6500 Washer Repair 0 07-18-2008 10:34 AM
