Discuss
LG fridge - poked tiny hole in coolant line
 in
Refrigerator & Freezer Repair
Recently both the frige and freezer were not as cold as they should be. Upon inspecting the freezer compartment (LG
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » LG fridge - poked tiny hole in coolant line
  #1 (permalink)
Old 03-26-2010, 11:55 AM
Junior Member
denversun is on a distinguished road
Default LG fridge - poked tiny hole in coolant line
Model Number: LG   Brand: -other-   Age: 1 - 5 years
Recently both the frige and freezer were not as cold as they should be. Upon inspecting the freezer compartment (LG counter depth side-by side, 14 months old) I noticed that there was significant ice build up around the vents where the cold air is circulated through the freezer compartment. I cleared the ice but realized that the ice build up was very substantial behind the interior molding. I removed the molding and noticed that the top portion of the condensor was encased within ice, and the ice extended at least another 10 inches up the back wall of the unit.
While attempting to remove the ice (which I did and amounted to over half a bucket) I ever so slightly nicked one of the copper supply lines for the refrigerant to move from the condensor and an immediate small leak developed. Note that I did not damage the condensor, just one of the two copper line (pictures attached). I immediately sealed the line with a very good tape which seems to have held. I know there is still pressure in the system.
I am wondering if this can be repaired. If the refridgerant could somehow be stopped a small bead or two of solder could seal the copper line, at least that is my novice opinion. Is this possible, and furthermore can more refrigerant be added back to the system? I am afraid that a repair man will come, say that it can't be fixed and then charge me for an entirely new compressor / condensor/ and all that labor!
The other issue, and I have already called LG about this which makes this even more of a delicate situation is that apparently the ice buildup was so bad, that the defrost cycle ran and the hot air could not escape through the condensor, so the bottom of the panel in the freezer melted! (pics attached). I am out of warranty but LG said that they *might* cover this problem (although my futzing around really hampers that possibility). Nevertheless, getting back to the main problem.... I have heard that once there is an issue of coolant or refrigerant leaking out that moisture can enter the system rendering it useless. My older uncle in the appliance repair business said to throw the entire unit to the curb and buy a new frige because "everything is made in mexico these days and is cheap and not worth fixing". I dont know if that is old-man-mentaility speaking or the truth so I am looking for an honest response from the community of professionals. I do not believe that the system has lost much coolant or that it is even possible that any moisture has entered the system since the leak was covered almost imeediately and was expelling gas, not sucking any in.
Related Models
Amana LG1009W DRYER- GAS
Amana LG1101 DRYER- GAS
Amana LG1112 WASHER-TOP LOADING
Amana LG1112 DRYER- GAS
Whirlpool LG2001XSW0 Residential Dryer
Amana LG2112L DRYER- GAS
Amana LG2112W DRYER- GAS
Amana LG2401 DRYER- GAS
Amana LG2412 WASHER-TOP LOADING
Amana LG2412 DRYER- GAS
Amana LG2501 DRYER- GAS
Amana LG2512 WASHER-TOP LOADING
Amana LG2512 DRYER- GAS
Amana LG2811 DRYER- GAS
Amana LG2812 WASHER-TOP LOADING
Amana LG2812 DRYER- GAS
Amana LG2902 WASHER-TOP LOADING
Amana LG2911 DRYER- GAS
Amana LG2912 WASHER-TOP LOADING
Amana LG2912 DRYER- GAS
Whirlpool LG3001XMW0 Residential Dryer
Whirlpool LG3001XMW1 Residential Dryer
Whirlpool LG3001XMW2 Residential Dryer
Whirlpool LG3001XPW0 Residential Dryer
Whirlpool LG3001XSW0 Residential Dryer
Whirlpool LG3006XPW0 Residential Dryer
Amana LG3412G DRYER- GAS
Amana LG3412L DRYER- GAS
Amana LG3412W DRYER- GAS
Amana LG3512L DRYER- GAS
Amana LG3512W DRYER- GAS
Amana LG3812L DRYER- GAS
Amana LG3812W DRYER- GAS
Amana LG3912L DRYER- GAS
Amana LG3912W DRYER- GAS
Frigidaire LG400AXD1 Wwh(v2) / 27 " Gas Laundry Center
Frigidaire LG400AXW1 Wwh(v1) / 27 " Gas Laundry Center
Frigidaire LG400MXD1 Wwh(v2) / 27 " Laundry Center
Frigidaire LG400MXD2 Wwh(v2) / 27 " Laundry Center
Frigidaire LG400MXW1 Wwh(v1) / 27 " Laundry Center
Frigidaire LG400MXW2 Wwh(v1) / 27 " Laundry Center
Frigidaire LG400SXD1 Wwh(v2) / 27 " Gas Laundry Center
Frigidaire LG400SXD2 Wwh(v1) / 27 " Gas Laundry Center
Frigidaire LG400SXD3 Wwh(v1) / Laundry Center
Frigidaire LG400SXW1 Wwh(v1) / 27 " Gas Laundry Center
Frigidaire LG400SXW2 Wwh(v2) / 27 " Gas Laundry Center
Frigidaire LG400SXW3 Wwh(v2) / Laundry Center
Amana LG4209L DRYER- GAS
Amana LG4209L2 DRYER- GAS
Amana LG4209W DRYER- GAS
Amana LG4209W2 DRYER- GAS
Amana LG4219L2 DRYER- GAS
Amana LG4219W2 DRYER- GAS
Amana LG4309L DRYER- GAS
Amana LG4309W DRYER- GAS
Amana LG4319L2 DRYER- GAS
Amana LG4319W2 DRYER- GAS
Amana LG4409L DRYER- GAS
Amana LG4409W DRYER- GAS
Amana LG4429L DRYER- GAS
Amana LG4429W DRYER- GAS
Whirlpool LG4441XWW0 Residential Dryer
Whirlpool LG4441XWW1 Residential Dryer
Amana LG4509L DRYER- GAS
Amana LG4509W DRYER- GAS
Amana LG4609L DRYER- GAS
Amana LG4609W DRYER- GAS
Amana LG4809L DRYER- GAS
Amana LG4809W DRYER- GAS
Amana LG4909L DRYER- GAS
Amana LG4909W DRYER- GAS
Whirlpool LG4931XMW0 Residential Dryer
Whirlpool LG4931XSW0 Residential Dryer
Whirlpool LG4931XTW0 Residential Dryer
Whirlpool LG4931XTW1 Residential Dryer
Whirlpool LG4931XTW2 Residential Dryer
Whirlpool LG4936XMW0 Residential Dryer
Whirlpool LG4936XMW1 Residential Dryer
Whirlpool LG5201XTW0 Residential Dryer
Whirlpool LG5201XTW1 Residential Dryer
Whirlpool LG5321XTW0 Residential Dryer
Whirlpool LG5531XKW0 Residential Dryer
Whirlpool LG5531XKW1 Residential Dryer
Whirlpool LG5531XMG2 GAS DRYER
Whirlpool LG5531XMN2 GAS DRYER
Whirlpool LG5531XMW0 Residential Dryer
Whirlpool LG5531XMW1 Residential Dryer
Whirlpool LG5531XMW2 GAS DRYER
Whirlpool LG5531XPW0 Residential Dryer
Whirlpool LG5531XSW0 Residential Dryer
Whirlpool LG5531XSW1 Residential Dryer
Whirlpool LG5536XPW0 Residential Dryer
Whirlpool LG5551XTG0 GAS DRYER
Whirlpool LG5551XTN0 GAS DRYER
Whirlpool LG5551XTW0 Residential Dryer
Whirlpool LG5601XMW0 Residential Dryer
Whirlpool LG5601XPW0 Residential Dryer
Whirlpool LG5601XSW0 Residential Dryer
Whirlpool LG5601XSW1 Residential Dryer
Whirlpool LG5606XPW0 Residential Dryer
Whirlpool LG5651XKW0 Residential Dryer
Whirlpool LG5651XKW1 Residential Dryer
Whirlpool LG5651XMW0 Residential Dryer
Whirlpool LG5651XMW1 Residential Dryer
Whirlpool LG5701XKW0 Residential Dryer
Whirlpool LG5701XMW0 Residential Dryer
Whirlpool LG5701XMW1 Residential Dryer
Whirlpool LG5701XMW2 Residential Dryer
Whirlpool LG5701XPW0 Residential Dryer
Whirlpool LG5701XSN0 GAS DRYER
Whirlpool LG5701XSW0 Residential Dryer
Whirlpool LG5706XPW0 Residential Dryer
Whirlpool LG5721XPW0 Residential Dryer
Whirlpool LG5721XSW0 Residential Dryer
Whirlpool LG5721XSW1 Residential Dryer
Whirlpool LG5726XPW0 Residential Dryer
Whirlpool LG5751XFW0 Residential Dryer
Whirlpool LG5751XKW0 Residential Dryer
Whirlpool LG5751XKW1 Residential Dryer
Whirlpool LG5751XMW0 Residential Dryer
  #2 (permalink)
Old 03-26-2010, 01:46 PM
Expert
APP Volunteer
FridgeDoctor is on a distinguished road
Default Before you decide to repair your own refrigerator
Well, I hate to disappoint you, but your uncle is right. It doesn't matter how quick you put the tape on, as soon as you punctured the evaporator, moisture immediately entered the system. You didn't slightly nick the copper tubing, you punctured it when you were chipping at the ice, with a screwdriver would be my guess, copper cannot be easily punctured, especially by slightly nicking it. The problem when moisture and oxygen enters the sealed system, it breaks down the refrigerant into hydrochloric and hydrofluoric acids, which then in turn damage the mechanical components. You have a major problem, and I'll save you a house call charge by telling you that the entire sealed system has to be replaced. If you only have the system evacuated and dehydrated, then recharge the system, which even if its done properly and legally, by an EPA Certified Type I Technician, in other words, not recommended for a DIYer, due to the process required, would still be a major repair, and would not last as long as it should due to the acid damage.<br><br>I hope people see this post, and realize why its not always a good idea to attempt a repair of a major house hold appliance on their own. I've had plenty of phone calls from potential customers, who if they had called for service sooner, wouldn't be shopping for a brand new refrigerator, and in the process spending 5-10 times what a repair service would have cost in the first place. <br><br>And one last bit of bad news, because this unit is not working, it is not eligible for the electric company's cash for clunkers appliance exchange program credit either.<br>
__________________
Refrigerator Repair Service to Chicago Suburbs
  #3 (permalink)
Old 03-26-2010, 02:12 PM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
Quote:
What does <br> mean?
  #4 (permalink)
Old 03-26-2010, 05:49 PM
Junior Member
Default
the previous user was attempting to add an html carriage return except the editor does not support such code, probably for security reasons.
Now back to the real problem.... You are correct on all accounts with the exception that it really wasn't very hard to puncture the think copper line (but thats not the point). Anyhow, the one part that I am having a very hard time wrapping head around is how the system could have been compromised. The system (and please correct me if I am wrong) is pressurized. Matter moves from high pressure to low pressure and the puncture I made was very small, and furthermore was covered up very quickly while the small hole was venting out (implying that there was still pressure in the closed system, yes?) Would the moisture be entering from another location (i.e condensation).
And, do you suggest that I do not have my system fixed, flushed, and recharged? My refrigerator was $2500 just over a year ago and of course wuld rather spend even a thousand dollars or more to get this fixed if necessary. Just trying to avoid a new refrigerator
Thanks for your input and detailed explanation, it is definitely much appreciated!
  #5 (permalink)
Old 03-26-2010, 06:10 PM
Expert
APP Volunteer
Default
you're right, the point is that you shouldnt have chipped away at the ice, puncturing your system. Instead you should have called an expert to at least diagnose your problem. You are going to spend close to that $2500 to repair everything you need to replace, its not worth it. And that repair wont come with a 5 year warranty either. Im sorry to say, but you cost yourself a much bigger headache than was necessary. An expensive lesson yes, but thats where you are right now.
__________________
  #6 (permalink)
Old 04-25-2010, 10:12 PM
Junior Member
Mickstix is on a distinguished road
Default
After you removed the ice, does it funtion properly now? If so, (since it's apparently doomed anyway) I'd leave the tape, and find out how long I could get it to last, before spending any more $$ on a new appliance! Good luck!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Hole in Hotpoint refrigerator dryer line Shawn68 Refrigerator & Freezer Repair 2 01-17-2010 07:44 AM
3.0 CU/FT coolant leak tedmueller7 Refrigerator & Freezer Repair 1 08-11-2009 07:36 PM
Tiny hole in drain pump elote2005 Washer Repair 1 06-18-2009 10:03 PM
Leaking plastic water line in fridge samoore105 Refrigerator & Freezer Repair 0 05-07-2009 06:54 PM
Water Line for Fridge rusty suor Refrigerator & Freezer Repair 1 04-09-2009 05:33 AM
