Discuss
Water to ice maker quit working
 in
Refrigerator & Freezer Repair
Have done the following: 1. Replaced the filter 2. Put in new optics kit.... did the check and it is
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Water to ice maker quit working
  #21 (permalink)
Old 08-31-2011, 05:16 PM
Junior Member
Dunsany is on a distinguished road
Default Gene...I have a similar problem
2. Put in new optics kit.... did the check and it is OK.
3. Put in new ice maker....did the jumper check and it went thru one ice harvest and re-filled with water. Now it is filled with ice but will not go thru a harvest cycle.
4. The valve cycles twice, and thats it. The tube is not frozen.
Any ideas...looks like I've tried everything?
Ads By Google
  #22 (permalink)
Old 08-31-2011, 10:22 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
What is the exact temperature in the freezer?
What is the complete model number of the refrigerator and the part number of the new ice maker?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #23 (permalink)
Old 09-01-2011, 05:36 AM
Junior Member
Default Reply
This is a Kitchen Aid Model KSRA25ILSS01 ... s/n SM1838777
Freezer Temp is 4 F
Original Ice Maker was p/n 2198597
The replacement has the following markings:
1. 185 W-115V-60 HZ ...which I assume is 185 watts at 115 volts etc.
2. IM #S 106 626640
Appreciate your guidance.
They installed a new Optic kit p/n 4389102.
When I look at the wiring schematic it appears that the door switch is part of the circuit as well...could this be the problem.
If I need to start over with all new parts so be it. The service people here do not seem to be up on these. First they say no power to the the ice maker, then they say it needs a new ice maker, then a optics kit, and on and on
  #24 (permalink)
Old 09-05-2011, 10:16 AM
Junior Member
DannyD is on a distinguished road
Default Thanks!
Thanks alot Gene! I replaced the icemaker in about 2o minutes and my mother is enjoying ice again. You saved me money on calling someone out to look at it, I am grateful as hard as money is to come by these days!
Danny
  #25 (permalink)
Old 09-05-2011, 09:02 PM
Junior Member
Default Did you receive my reply?
I replied last week...did you receive?
  #26 (permalink)
Old 09-07-2011, 12:37 PM
Junior Member
Default Are my postings getting thru?
Quote:
01-2011 05:36 AM Dunsany Quote:
Freezer Temp is 4 F
2. IM #S 106 626640
If I need to start over with all new parts so be it. The service people here do not seem to be up on these. First they say no power to the the ice maker, then they say it needs a new ice maker, then a optics kit, and on and on 08-31-2011 10:22 PM Gene What is the exact temperature in the freezer?
Gene. 08-31-2011 05:16 PM Dunsany Have done the following:
Read more: http://forum.appliancepartspros.com/...#ixzz1XITalufJ
  #27 (permalink)
Old 11-07-2011, 12:22 PM
Junior Member
Tonya44 is on a distinguished road
Default Ice Maker Not working.
I have a Kitchen Aid side by side fridge Model # KSCS25INSS00. I replaced the entire ice maker. Will make one tray(fills, freezes and dispenses, next time it will fill with water, but will not eject the ice. If I take it out and put it back in it works once, then stops again. The LED is blinking, and if I close the flapper door it stays solid. Would that mean the board needs replacing too? Thanks.
  #28 (permalink)
Old 11-07-2011, 12:31 PM
Junior Member
mallisonb is on a distinguished road
Default
I had a similar problem with my whirlpool. I replaced the optics boards and the icemaker. It didn't work at first but after a day or so it started cranking out ice and hasn't stopped yet. I think since the cycling of the icemaker is temperature dependent, the thermostat in the icemaker has to equilbrate with the freezer temperature.
  #29 (permalink)
Old 11-07-2011, 02:30 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Freezer Temp is 4 F
2. IM #S 106 626640
Very sorry for such delay. I was on vacation and then somehow overlooked your post.
If the status LED stays On while the emitter door on the left side closed then very likely the new ice maker is defective. It has to be exchanged under the parts warranty.
__________________
  #30 (permalink)
Old 08-05-2012, 08:55 AM
Junior Member
Charles Brown is on a distinguished road
Default
Wanted to thank Gene for his helpful test procedures. It helped us find out that the bad part was the valve and not the maker itself. Also want to say that we ordered the valve here on Thursday evening and the part arrived Saturday morning using standard ground shipping. Thanks!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ice Maker quit working Ralf Refrigerator & Freezer Repair 0 10-12-2009 06:43 PM
Ice maker quit working 647sam Refrigerator & Freezer Repair 2 06-29-2009 12:34 PM
Ice Maker quit working jayb Refrigerator & Freezer Repair 1 12-30-2008 04:30 PM
Ice Maker Quit Working JAMJR Refrigerator & Freezer Repair 0 02-28-2008 07:06 AM
Ice Maker quit working tips Refrigerator & Freezer Repair 0 10-17-2007 03:16 PM
