| » Water to ice maker quit working |
Gene;
My icemaker has been out for some time, so I ran the tests you recommended below. There is no voltage across the N&L terminals. However, when I unplugged the icemaker and measured the voltage across incoming leads, it was only about 92-93 volts and the voltage going to the water valve is only about 89-90 volts. Is this normal for a Whirlpool? Model No. GD5RHAXNQ00. Before I buy a new icemaker, however, the compressor has been making a knocking noise about every hour or so. This has been going on for the better part of a year. The compressor appears to be well anchored to the bracket but is hot to the touch (if that means anything bad). Otherwise, both refrigerator and freezer (side by side) appear to be cooling adequately. Just measured the freezer at between 10 and 0 degrees F. Is this knocking noise a problem a pro can easily fix or is it an indication that my refrigerator is on its way out. Thanks Quote:
Quote:
In regards of the ice maker problems, you may want to replace the optic boards first. Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Gene.[/quote] So even if the red light appears to be functioning correctly, the optics boards can effect the functionality of the icemaker? |
Yes, because it supplies power for the ice maker.
__________________
By the way, after pulling my refrigerator away from the wall and removing the little cardboard panel that covers the compressor, I haven't heard the compressor make that knocking noise. The fridge is still sitting in the middle of my kitchen floor so I don't know if moving it back will have any effect. Not sure why it would unless sitting in a corner creates a lot of heat build up that stresses the compression and makes it act up.
Thanks for what you do. You've been a great help. |
You are welcome.
It's hard to say what caused that noise. It could the cardboard cover interfering with some moving parts, the fan blade touching the frame or something else like that. Carefully move it back in place and make sure it is leveled and the floor under the refrigerator is firm. Gene.
__________________
I have an icemaker with similar concern, I have replaced the dual water valve and still get no water. Do I replace the module or is it chaeper and feasible to replace icemaker assy? I am going to test the jumper wire this evening. Thanks in advance!
Danny,
If the temperature in the freezer is no more than 5°F and the water line into the ice maker is not blocked then the solution is to replace the whole ice maker. It makes the repair much more reliable than fixing the old ice maker. If the ice maker harness plug is flat then you can use the ice maker Part number: AP4360346 Otherwise you have to order the ice maker Part number: AP2984633 Here are the breakdown diagrams and Replacement parts for WHIRLPOOL RS22AQXMQ00 REFRIGERATOR | AppliancePartsPros.com Gene.
__________________
| Display Modes | |
| Ice Maker quit working | Ralf | Refrigerator & Freezer Repair | 0 | 10-12-2009 06:43 PM |
| Ice maker quit working | 647sam | Refrigerator & Freezer Repair | 2 | 06-29-2009 12:34 PM |
| Ice Maker quit working | jayb | Refrigerator & Freezer Repair | 1 | 12-30-2008 04:30 PM |
| Ice Maker Quit Working | JAMJR | Refrigerator & Freezer Repair | 0 | 02-28-2008 07:06 AM |
| Ice Maker quit working | tips | Refrigerator & Freezer Repair | 0 | 10-17-2007 03:16 PM |
