Discuss
fridge and freezer not cooling or freezing
 in
Refrigerator & Freezer Repair
Hi. Please provide the model number of the unit. Simon.
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » fridge and freezer not cooling or freezing
  #21 (permalink)
Old 07-25-2012, 02:06 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #22 (permalink)
Old 07-25-2012, 02:13 PM
Expert
Default
Hi, mrdrywall.
From the info you provided I think that there is a bad cold control (one on the left).
Freezer control Part number: 5304421067
Here are the breakdown diagrams and Replacement parts for Frigidaire FRS26R2AWB Frigidaire/refrigerator | AppliancePartsPros.com
You can use the old sleeve.
Thank you. Post the results.
Simon.
__________________
  #23 (permalink)
Old 08-10-2012, 08:16 AM
Junior Member
joegrent is on a distinguished road
Default
Same model as the OP ET1MTMXKQ00 so just adding to the thread.
Fridge stopped working on Monday (got it going but did not figure out the problem) and then this morning before going to work.
Do not have the wiring diagram for this model (miss the old days of the diagraming being in the manual or a paper on/in the compressor area or a sticker on the fridge).
The whole fridge (no sound from the compressor, cond fan, evap fan) stopped working after it started for about 3-5 seconds. I adjusted the temperature control in the fridge and it did not start. Rotated it around to clean the contacts and then juggled it, no go (cranked it too a much cooler temperature). Eat breakfast and then opened the back up and tapped the starter on the compressor still no go. Compressor was warn to the touch as excepted but not hot. Removed the starter and gave it a shake and no rattle. Connected the wiring back to it and connected it back to the compressor, no go. Removed the starter and cond fan connecter and checked some voltages 0 volts on all as I excepted since nothing is running (with main line voltage at 120V, measured first). Did some more plugging and unplugging the main line with the starter off the compressor and the fan connector replaced. Heard no clicks until after one of the plug ins, I heard a click and the cond fan started up. Measured the voltage on the starter. Unplugged the main and unplugged the cond fan. Listened for where the click sound would come from when I plugged the main and it sounded like it was coming from somewhere to the right near where the connecter where the main connects to the fridge (maybe hearing echoes from somewhere else???). Measured the voltages on the fan and starter, 120V. Re-connected everything and all working as normal.
Any opinions on what it could be? I wanted to disconnect the wiring assembly and directly connect the main to the compressor and cond fan (jumping the wiring assembly) to the bypass the control circuit up in the fridge but had to go to work and since it started working I left it.
  #24 (permalink)
Old 08-10-2012, 10:13 AM
Expert
Default
Hi.
You may have the problem with the defrost timer or cold control.
Next time when the fridge will be acting up locate the round opening at the bottom of the control box. Using the flat screw driver slowly turn the timer's shaft CW until it click.
If the fridge starts - replace the timer.
Defrost timer Part number: 482493
Part number: 482493
Here are the breakdown diagram and Liner replacement parts for Whirlpool ET1MTMXKQ00 REFRIGERATOR | AppliancePartsPros.com
Simon.
__________________
  #25 (permalink)
Old 08-10-2012, 04:20 PM
Junior Member
Default
Thanks,
Could be as the first time I opened the fridge just as I started up and then shutdown 2 seconds later and the second time I just closed the door and then it started for the 3-5 seconds before it shutdown.
Currently working normally.
Quote:
Originally Posted by Simon / APP Team View Post
Post the results.
Most definitely as this is the point of the forum.
  #26 (permalink)
Old 02-22-2013, 04:40 PM
Junior Member
Default
Final turned off just 5 minutes ago. The fridge started up and within 3 seconds shut off. Slowly turned the timer CW (it clicked about 5-7 times) and then the final click was louder and the fridge started up. Ran normally, shut down and then started up as normal.
Thanks for the help
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE - fridge freezing in drawers, freezer not freezing at top, but coils frozen over jaxcarlson Refrigerator & Freezer Repair 0 12-01-2009 09:42 AM
Fridge Freezer constantly running not cooling or freezing thechancer2000 Refrigerator & Freezer Repair 1 08-12-2009 03:46 AM
freezer not freezing fridge not cooling che Refrigerator & Freezer Repair 1 07-10-2009 06:36 AM
Freezer and Fridge not cooling/freezing moderdm Refrigerator & Freezer Repair 5 10-04-2008 06:50 PM
Amana Fridge not cooling or freezing karl Refrigerator & Freezer Repair 0 06-18-2008 11:10 PM
