Discuss
Freezer Problems
 in
Refrigerator & Freezer Repair
My Whirlpool is collecting sheets of ice on the bottom of my side by side refrigerator. i think the defrost
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer Problems
  #1 (permalink)
Old 06-04-2008, 01:49 PM
Junior Member
Katie is on a distinguished road
Default Freezer Problems
Brand: Whirlpool   Age: 1 - 5 years
My Whirlpool is collecting sheets of ice on the bottom of my side by side refrigerator. i think the defrost coil may be blocked. How do I clean it?
  #2 (permalink)
Old 06-04-2008, 01:53 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
The defrost drain hole is most likely clogged. look at the bottom of the back wall of the freezer, there is a hole that water runs down, and by now it is frozen over. You will need hot water and a turkey baster to clear the drain. Keep forcing hot water down the drain till it is clear.
__________________
  #3 (permalink)
Old 06-04-2008, 01:57 PM
Junior Member
Default
Is the drain hole on the inside of the freezer?
  #4 (permalink)
Old 06-04-2008, 01:58 PM
Junior Member
Default
And if I do keep putting hot water down there, where does the water go to?
  #5 (permalink)
Old 06-04-2008, 02:32 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
yes, at the bottom of the back wall
__________________
  #6 (permalink)
Old 06-04-2008, 02:33 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
Once clear, the water goes down the drain into the drain pan
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Icemaker/freezer problems bofusmosby Refrigerator & Freezer Repair 1 11-30-2009 04:51 PM
Freezer Problems nealppjr Refrigerator & Freezer Repair 1 07-11-2009 03:05 PM
PROBLEMS WITH FRIDGE and FREEZER Fustrated Refrigerator & Freezer Repair 3 04-22-2009 12:57 PM
Freezer Problems Russ Refrigerator & Freezer Repair 21 12-23-2007 10:55 AM
Refrigerator/freezer problems imthewraith Refrigerator & Freezer Repair 3 09-17-2007 03:28 PM
