Appliance Repair Forum
Appliance Repair Forum (
-   Refrigerator & Freezer Repair (
-   -   Ice dispenser and Water working icemaker not (
shellyray15 06-03-2008 09:47 PM
My ice maker does not seem to be filling with ice. Normally you can hear the water running into it, but not lately. It looked like a little water had run into it and stopped. Then the arm never rotated it out. My husband took it apart and said it looked like a little piece of ice was stuck, he then freed it and since nothing else has happened. Any help would be greatly appreciated. THANK YOU
owenbrewer 06-04-2008 07:14 PM
manual test
add water with a cup directly into the cube compartment. If it works for that load it is either a stopped up supply line or there is no water getting to the ice tray.
Gene 06-06-2008 09:11 PM
Hi Shelly,
You can find the complete instructions in one of our previous posts:
After you will do it, post the results.
Here are the break down diagrams for the Whirlpool refrigerator Model ED2CHQXKQ05
shellyray15 06-07-2008 08:36 AM
Ice Maker not working
Hi Gene, I just now got your message. I tried what Owen said with putting the water in and seeing if it would freeze and rotate the ice out and it did not. After that I was just going to go buy another ice maker.
Thank you both for your input.
Gene 06-07-2008 04:52 PM
Just in case, the part number for the ice maker is AP2984633
Keep us posted.
