I have an up right freezer that is working but the electronic temp control panel on the outside of the freezer has stopped working. I can't see the temp display now. When I popped the control panel out & then put it back in the High Temp & Door Ajar boxes lite up then when out again. Do you think the control panel needs to be replaced?
It may just be a bad electrical connection between the unit and the display panel.
