Discuss
Kitchen Aide Side by Side Freezer cold Refrigerator warm
 in
Refrigerator & Freezer Repair
My Kitchen Aide Refrigerator is not cooling the refrigerator side. The freezer is working fine. There is alot of ice
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Kitchen Aide Side by Side Freezer cold Refrigerator warm
  #1 (permalink)
Old 03-23-2010, 11:05 AM
Junior Member
vbarajas is on a distinguished road
Default Kitchen Aide Side by Side Freezer cold Refrigerator warm
Model Number: KSRA25ILSS02   Brand: Kitchen Aid   Age: 5 - 10 years
My Kitchen Aide Refrigerator is not cooling the refrigerator side. The freezer is working fine. There is alot of ice or frost build up on the freezer side,so it might be working to hard. I had a repair man come and he told me that the vents were full of ice. He defrost them and it was working great for three weeks and know the vents are doing the same thing. There is nothing blocking the vents. I have vacummed the refrigerator, the door gaskets are good, plus the doors are shutting tight every time after opening.
Ads By Google
Related Models
Whirlpool KSRA25ILSS03
Whirlpool KSRA25ILSS13 Refrigerator
Whirlpool KSRA25ILWH00 Refrigerator
Whirlpool KSRA25ILWH01 Refrigerator
Whirlpool KSRA25ILWH03
Whirlpool KSRA25ILWH13 Refrigerator
Whirlpool KSRA25KKBL00
Whirlpool KSRA25KKBL01
Whirlpool KSRA25KKBL02 Refrigerator
Whirlpool KSRA25KKBL12 Refrigerator
Whirlpool KSRA25KKBT00
Whirlpool KSRA25KKBT01
Whirlpool KSRA25KKBT02 Refrigerator
Whirlpool KSRA25KKBT12 Refrigerator
Whirlpool KSRA25KKSS00
Whirlpool KSRA25KKSS01
Whirlpool KSRA25KKSS02 Refrigerator
Whirlpool KSRA25KKSS12 Refrigerator
Whirlpool KSRA25KKWH00
Whirlpool KSRA25KKWH01
Whirlpool KSRA25KKWH02 Refrigerator
Whirlpool KSRA25KKWH12 Refrigerator
Whirlpool KSRA25KNSS00 Refrigerator
Whirlpool KSRA25KNSS01 Refrigerator
Whirlpool KSRA25PNBL00 Refrigerator
Whirlpool KSRA25PNBT00 Refrigerator
Whirlpool KSRA25PNLK00 Refrigerator
Whirlpool KSRA25PNSS00 Refrigerator
Whirlpool KSRA25PNWH00 Refrigerator
Whirlpool KSRB22DWAL02
Whirlpool KSRB22DWWH02
Whirlpool KSRB22FGBL00
Whirlpool KSRB22FGSS00
Whirlpool KSRB22FGWH00
Whirlpool KSRB22FHBL00
Whirlpool KSRB22FHBL01
Whirlpool KSRB22FHBL02
Whirlpool KSRB22FHBL03
Whirlpool KSRB22FHBL04
Whirlpool KSRB22FHBL05
Whirlpool KSRB22FHBL06
Whirlpool KSRB22FHBT01
Whirlpool KSRB22FHBT02
Whirlpool KSRB22FHBT03
Whirlpool KSRB22FHBT04
Whirlpool KSRB22FHBT05
Whirlpool KSRB22FHBT06
Whirlpool KSRB22FHSS00
Whirlpool KSRB22FHSS01
Whirlpool KSRB22FHSS02
Whirlpool KSRB22FHSS03
Whirlpool KSRB22FHSS04
Whirlpool KSRB22FHSS05
Whirlpool KSRB22FHSS06
Whirlpool KSRB22FHWH00
Whirlpool KSRB22FHWH01
Whirlpool KSRB22FHWH02
Whirlpool KSRB22FHWH03
Whirlpool KSRB22FHWH04
Whirlpool KSRB22FHWH05
Whirlpool KSRB22FHWH06
Whirlpool KSRB22FKBL00
Whirlpool KSRB22FKBL01
Whirlpool KSRB22FKBL02
Whirlpool KSRB22FKBL03 Refrigerator
Whirlpool KSRB22FKBL04 Refrigerator
Whirlpool KSRB22FKBL14 Refrigerator
Whirlpool KSRB22FKSS00
Whirlpool KSRB22FKSS01
Whirlpool KSRB22FKSS02
Whirlpool KSRB22FKSS03 Refrigerator
Whirlpool KSRB22FKSS04 Refrigerator
Whirlpool KSRB22FKSS14 Refrigerator
Whirlpool KSRB22FNSS00 Refrigerator
Whirlpool KSRB22FRBX00 Refrigerator
Whirlpool KSRB22FRBX01 Refrigerator
Whirlpool KSRB22FRBX02 Refrigerator
Whirlpool KSRB22FTBX00 Refrigerator
Whirlpool KSRB22QABL00
Whirlpool KSRB22QABL10
Whirlpool KSRB22QABL11
Whirlpool KSRB22QABL12
Whirlpool KSRB22QDBL00
Whirlpool KSRB22QDBL01
Whirlpool KSRB22QDBL02
Whirlpool KSRB22QFBL00
Whirlpool KSRB22QFBL01
Whirlpool KSRB22QFSS00
Whirlpool KSRB22QFSS01
Whirlpool KSRB22QGBL00
Whirlpool KSRB22QGSS00
Whirlpool KSRB22QXAL00
Whirlpool KSRB22QXBL00
Whirlpool KSRB22QXWH00
Whirlpool KSRB25FBBL00
Whirlpool KSRB25FGBL00
Whirlpool KSRB25FGBT00
Whirlpool KSRB25FGSS00
Whirlpool KSRB25FGWH00
Whirlpool KSRB25FHBL00
Whirlpool KSRB25FHBL01
Whirlpool KSRB25FHBL02
Whirlpool KSRB25FHBL03
Whirlpool KSRB25FHBL04
Whirlpool KSRB25FHBL05
Whirlpool KSRB25FHBT00
Whirlpool KSRB25FHBT01
Whirlpool KSRB25FHBT02
Whirlpool KSRB25FHBT03
Whirlpool KSRB25FHBT04
Whirlpool KSRB25FHBT05
Whirlpool KSRB25FHSS00
Whirlpool KSRB25FHSS01
Whirlpool KSRB25FHSS02
Whirlpool KSRB25FHSS03
Whirlpool KSRB25FHSS04
Whirlpool KSRB25FHSS05
Whirlpool KSRB25FHWH00
Whirlpool KSRB25FHWH01
Whirlpool KSRB25FHWH02
  #2 (permalink)
Old 03-23-2010, 11:47 AM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
The ice build-up in the freezer (especially if it's snowy) means you have a defrost failure. This can be caused by a defrost heater or thermostat failure, or the adc (adaptive defrost control board)/defrost timer failure. You can check the first two rather easily: Remove everything from the freezer and let it defrost (unplug the machine). Remove the panel at the rear of the freezer compartment (inside it) to expose the evaporator. The heater will have two wires going up along the sides of the evaporator. Careful: the radiating fins are very sharp! Unplug the heater and test it for continuity. If there isn't any, replae it. The thermostat is usually clipped to one of the evaporator coil tubes; about the size of a stack of 10 nickels. If it looks swollen, replace it. It should be open (have no continuity) at room temperature, and closed (have continuity) at freezing.
  #3 (permalink)
Old 03-23-2010, 08:11 PM
Junior Member
Default Kitchen Aide Side by Side Results from Tech
Had a tech come and look at the refrigerator and I mention the three possible solustions that were recommended. He told me (no) that he belives that I need to replace the defuser. He took the cover for the defuser off from the freezeer and refrigerator and took the ice off. At the bottom vent of the refrigerator he took the cover off and stared pooring hot water to defrost the ice that it had built up. What do you think should do, replace teh defuser?
He mention that the reason it is snowing on the freezer side is because the defuser is not passing enough cold air to the refrigerator side that it is to cold on the freezer side. He told me that the defuser is subpose to let cool air come in from the freezer and it is not opening all the time becuase it is freezing.
Please let me know what you think.
  #4 (permalink)
Old 03-24-2010, 07:59 AM
Senior Expert
APP Volunteer
Default
Not real sure what your tech is calling a "defuser". If you trust this tech, go with what he says. Keep us posted.
  #5 (permalink)
Old 04-13-2010, 08:50 PM
Junior Member
Default
Have not had a chance to take the panel appart and check the three recommend solotions. My wife has been unplugging the refrigerator and pooring warn water down the bottom vent an removing the ice build up on the top vent and lower vent too. She is know telling me that food is freezing in the lower two meat and veggitable cuburds. Also on the lower two sheleves. Could this still be that same problem causing this issue.
  #6 (permalink)
Old 11-20-2011, 01:25 PM
Junior Member
galford99 is on a distinguished road
Default Same problem, frost on and around icemaker is clogging airflow chambers with ice.
Quote:
WHAT WAS THE FIX??
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire side by side refrigerator freezer working refrigerator not cold enough SSOWDERS Refrigerator & Freezer Repair 1 09-19-2009 09:00 AM
Side by Side Fridge & Freezer Warm at top but cold on bottom rosnik Refrigerator & Freezer Repair 7 04-06-2009 03:02 PM
Maytag side by side Freezer cold Refrig warm timbruns Refrigerator & Freezer Repair 2 06-10-2008 05:11 PM
Freezer Cold,But refrig warm (Side/Side) oceanrunner Refrigerator & Freezer Repair 5 12-28-2007 09:19 PM
side by side refrigerator /freezer blows warm air truleygood Refrigerator & Freezer Repair 3 12-28-2007 02:19 AM
