Discuss
GE side-by-side refrigerator
 in
Refrigerator & Freezer Repair
My freezer compartment is not getting cold enough. It will only cool to 20 degrees and is not making ice
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » GE side-by-side refrigerator
  #1 (permalink)
Old 06-02-2008, 10:51 AM
dmc56 dmc56 is offline
Junior Member
dmc56 is on a distinguished road
Smile GE side-by-side refrigerator
Model Number: GSH25KGMBWW   Brand: GE   Age: 5 - 10 years
My freezer compartment is not getting cold enough. It will only cool to 20 degrees and is not making ice cubes (I'm assuming that is because of the temperature problem) Any suggestions? Thank you!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-02-2008, 11:05 AM
abadfish66's Avatar
abadfish66 abadfish66 is offline
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
1. do you see any frost on the back wall of the freezer?
2. how is the freshfood temp?
3. is the freezer fan running, open door push in light switch and check if fan is running.
4. with both doors open, is the center divider hot to the touch, or very warm..
Post the results and I will help you along
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!!
Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up.
  #3 (permalink)
Old 06-02-2008, 11:37 AM
Junior Member
Smile
answers:
1. No frost on back wall of the freezer.
2. Freshfood temperature is fine.
3. Fan is running.
4. The center divider is hot to the touch.
Thank you so much for any help you can give!
  #4 (permalink)
Old 06-02-2008, 11:52 AM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
Pull the fridge out, and remove the bottom access cover at the rear, and see if the condensor fan is running. also check the condensor to see if it is covered in lint and dust. he reason it is not cooling is 1 of those 2 things...keep me posted
__________________
  #5 (permalink)
Old 06-03-2008, 11:20 AM
Junior Member
Thumbs up
I took your advice...pulled the refrigerator out and found an abundance of dust bunnies! The condenser fan was running fine. I gave everything a thorough cleaning and the temperature has been going down ever since! In fact, I had to adjust the temperature control in both the refrigerated and freezer sides because this morning the freezer compartment was at -20 degrees and the refrigerated compartment was hovering close to the freezing mark. Now there's still no ice being made, but with the cold temps, I checked my water filter and found ice, so I removed it and right now the defrost cycle is running, so hopefully the water lines will unthaw and that will correct the ice making problem. Thanks again abadfish66...it feels great not to have to call a repairman!!
  #6 (permalink)
Old 06-03-2008, 11:24 AM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
Your welcome, now the reason you probably noticed it so cold in the freezer is because it went into pre-chill. One the refer stablizes you'll be fine, just be carefull about the waterfilter freezing you'll have one heck of a mess if that thing bursts. Make sure you have a good load of food in both sections and you will be fine....glad I could help
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
side by side refrigerator stopped cooling and freezing bbcowboy Refrigerator & Freezer Repair 3 03-21-2008 07:02 PM
side by side refrigerator /freezer blows warm air truleygood Refrigerator & Freezer Repair 3 12-28-2007 03:19 AM
ice shoot flap won't close on ge side by side refrigerator amyp Refrigerator & Freezer Repair 1 11-28-2007 09:05 AM
Amana Side by Side Refrigerator Evaporator Fan Question beachesfour Refrigerator & Freezer Repair 1 10-17-2007 04:10 AM
Amana Side by Side Refrigerator Freezer MFG. P1317202WE josephbowles@earthlink.ne Refrigerator & Freezer Repair 0 08-10-2007 06:38 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
