Discuss
Old Freezer Ignorant -- Please help.
 in
Refrigerator & Freezer Repair
Evening, Was given an old Mongomery Ward's chest freezer, told it worked fine. Unloaded it from trailer, dragged it
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Old Freezer Ignorant -- Please help.
  #1 (permalink)
Old 06-01-2008, 11:23 PM
Ableberry Ableberry is offline
Junior Member
Ableberry is on a distinguished road
Question Old Freezer Ignorant -- Please help.
Model Number: HMG8935OOB   Brand: -other-   Age: Less than 1 year
Evening,
Was given an old Mongomery Ward's chest freezer, told it worked fine. Unloaded it from trailer, dragged it across garage, plugged it in and nothing happened. No whirr of the compressor, clicking of electrical parts or anything.
Where do I begin to diagnose this thing? I noticed two plugs -- one for the compressor, the other leads to the thermostat I think. I plugged both in and still nothing.
Any and all help is needed!!
-Wes
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 06-01-2008, 11:40 PM
abadfish66's Avatar
abadfish66 abadfish66 is offline
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
When you say you found 2 plugs, what does the wiring look like at the compressor. Also does this have any indicator lights or anything that will tell you power is going to the freezer
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!!
Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up.
  #3 (permalink)
Old 06-02-2008, 06:15 AM
ApplianceJunk's Avatar
ApplianceJunk ApplianceJunk is offline
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
The first step would be to make sure you have power at the outlet that you plugged the freezer into.
__________________
You can Repair your Appliance & we can help with our Appliance Repair Forum and Appliance Repair Blog.
  #4 (permalink)
Old 06-02-2008, 11:38 AM
Junior Member
Default
Looks like there's an indicator light on the door. Doesn't light up when plugs are plugged in. The outlet does have power. Temperature setting is set to cold.
  #5 (permalink)
Old 06-02-2008, 11:54 AM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
trace the wires starting from the wall outlet, and look for a loose or broken wire somewhere
__________________
  #6 (permalink)
Old 06-03-2008, 12:14 AM
Junior Member
Default
Seems like a good place to start. And it stands to reason things might have been shifted in transit. Thanks!
  #7 (permalink)
Old 06-03-2008, 03:45 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Your defrost timer may be stuck in defrost, just check by turning it, should be in the back of the freezer, or behind the control panel, a black box with 4 wires going to it.
__________________
  #8 (permalink)
Old 06-03-2008, 01:46 PM
Junior Member
Default
Will look at the defrost timer, thanks. Standby for results.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer cold, evaporator fan not working, frost build up in freezer heretolearn2 Refrigerator & Freezer Repair 3 05-28-2008 03:45 PM
whirlpool fridge gt2shmxms04 freezer warmed and frosting freezer help ianandamy Refrigerator & Freezer Repair 3 05-07-2008 03:29 PM
Fridge OK Freezer temps vary widely slow ice and slow freezer fan start shado118 Refrigerator & Freezer Repair 2 04-24-2008 06:07 PM
Freezer Coils not defrosting and Ice in bottom of freezer bobbertj Refrigerator & Freezer Repair 2 04-06-2008 08:54 AM
Refrigerator/Freezer has liquid leaking inside freezer and frig terrib Refrigerator & Freezer Repair 0 12-25-2007 11:15 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
