Tested Defrost Timer, Continuity Good When Advancing Timmer Shaft , Defrost Thermostat Checks With Continuity When Warm And Then When Placed In Freezer, Defrost Heater,no Conitinuity,1/4" Tube Has A Crack On One Of The Bends Visually Hollow Inside, Continuityon Both Sides Of The Tube. No Continuity From Bullet Connctor To Tube Either Side
Here are your parts Replacement parts for FRIGIDAIRE FRS26ZRGWA Frg(v3) / Refrigerator | AppliancePartsPros.comHere is a wiring diagram/tech sheet. http://manuals.frigidaire.com/prodinfo_pdf/Anderson/218909400.pdf[COLOR="Blue"]Tested Defrost Timer, Continuity Good When Advancing Timmer Shaft[/COLOR] Not sure how you measured this so cannot comment. [COLOR="Blue"] Defrost Thermostat Checks With Continuity When Warm And Then When Placed In Freezer[/COLOR] This is a problem. The thermostat should be open (infinite ohms) at room temperature and closed (0 ohms) when frozen, see the tech sheet. [COLOR="Blue"], Defrost Heater,no Conitinuity,1/4" Tube Has A Crack On One Of The Bends Visually Hollow Inside, Continuityon Both Sides Of The Tube. No Continuity From Bullet Connctor To Tube Either Side[/COLOR] You lost me here. The defrost heater should measure approximately 22 ohms, see the tech sheet |
THIS FORUM IS DEAD!!!!!!! |
